RalphVa
Super Member
- Joined
 - Dec 19, 2003
- Messages
 - 7,902
- Location
 - Charlottesville, VA, USA
- Tractor
 - JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I also had a Fiat 124S 4 door sedan plus a couple of Fiat 1100s that were STILL all over India just 25 years ago.  Loved the Fiat but it was a torch and hacksaw car.  Seems no bolt ever unbolted like a bolt should.  It had to be either hacksawed or cut off.  Replaced the ball joints twice in 80k miles on the 124S.  Even had to replace the rear anti-sway bar, again, having to cut the bolt that held it on one end.  The first refinery I worked at had Fiats as work cars about the refinery.  Parts kept falling off the dash on them.  These were ones just a smidgen bigger than the little 500s.  Must have been 850 sedans.  I've rented several Fiats my 12 times to Sicily plus 2 or 3 Alfas.  My most favorite sedan was an Alfasud.
Hopefully, Fiat has solved its quality and, in particular, its rust problems. Think almost all manufacturers found the fix to rust back in the 80s. Seems to be mostly a by-gone problem with the phosphate dipping, etc. My Alfa was a MUCH higher quality machine. It was it that got me onto higher quality machines like our present 1983 240D Benz that'll probably go on forever. Just replaced the timing chain on it to get back maybe about 5 hp of its 65 hp, due to retarded valve timing by the stretched chain. It's a bit sassier now.
Oh, there's an Alfa bob-tail (probably a 1750) spider that I see occasionally about the Charlottesville area.
Ralph
Ralph
