Why are my front tires flat all the time!!!
   / Why are my front tires flat all the time!!! #11
I've put over $30 worth of Green Slime in my two front tires since early September. Yesterday, as I was piling firewood in my FEL, I noticed that one of the tires was again nearly flat.
I'd have been much better off putting tubes in them when I first started having problems last summer. I'm getting tubes put in on Friday. This tractor is only three years old, treated like a member of the royal family, but one of the front tires always seems to be flat.
Sheesh.
Everything I own seems to have flat tires. Both of my trailers, my rototiller, my snowblower, my log splitter, my lawn tractor -- and the lawn tractor's trailer, all have at least one flat tire right now.
I guess it is good that chain saws don't have tires.:(
I'm on the phone right now with a tire shop.....just waiting for a price guess on foaming the fronts.
Still waiting...... this hold music sucks..... "Kaltire's commitment to customers is in it's technician training"....
Has to get back to me.... let me get back to you all later.
-Jer.
There $250 per tire to foam them..... forget it!!! Interestingly they also said it'd add about 125lbs per tire. I'm getting tubes put in as soon as I can get the tires off the machine.
-Jer.
Do you live on a reclaimed roofing nail factory???
:p
-J.
   / Why are my front tires flat all the time!!! #14
At work I've had a lot of tires like that. Usually put in tubes or apply bead sealer.
Tubes are $30 a piece. I'll take 'em.....
-J.
   / Why are my front tires flat all the time!!! #17
Actually if I was going to guess the problem I would guess that as it gets colder the metal shrinks affecting the bead. My wife bent a rim and it never went flat so she did not worry about it. The first morning it turned cold she went out and the tire was flat. I put slime in it so she could drive to work and it held air for over a year until she needed new tires and we bought a new rim to go with it.
The poster that had problems with slime and still leaking I have not had that problem. I have slime in all of my tires. I have run over a few locust limbs and get small holes in my tires the slime has cured all of that. Before I spent 30.00 dollars a piece on tubes I would slime them. If you get small leaks you are either going to have to slime the tubes or you are going to be taking those tires to have them fixed every time you get a puncture. With tubeless tires you can at least plug them yourself.
   / Why are my front tires flat all the time!!! #18
I 'slimed' a few small tires without success, the went flat anyway.
When I pulled the tires the slime was frozen in clumps.
Looked to me as if the product was a latex or water based product.
Went with tubes!
(To be fair it was not Slime brand name.).
   / Why are my front tires flat all the time!!! #19
Add more air than is called for, and just spray those tires with a 90/10 mixture of water and soap. included stem. I can almost bet you have a slow leak somewhere. That air is going somewhere, and it will show up as bubbles. Replace the stem if you have to.
Slime or Multiseal will work. If you want to, put tubes in.
   / Why are my front tires flat all the time!!! #20
I had a trailer tire do that once a few days after getting new tires mounted. I found it by submerging it in water. I took a small hammer and hit the bead of the rim and it sealed it back. It's been up for months now without any problems.
Until tomorrow of course, because I'm bragging on it.
I had my 4-wheeler tires factory sealed when I purchased it and yet to have a flat or low tire. Not sure what they used, but it wasn't the green slime.
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
Unused Delta Crash...
12ft Heavy Duty Aluminum Ramps (A53473)
12ft Heavy Duty...
2002 MACK CH (A53843)
