3 pt leaks up & control lever moves as well
   / 3 pt leaks up & control lever moves as well #1
North Dakota
Mandan ND
'84 Ford 1710
On my 1984 ford 1710 the 3 pt as started leaking up when I'm using it. The control lever for raising and lowering the 3 pt moves on its own as it does this. If I hold the control lever or put a stop behind it then the 3pt does not leak up any more.
What would cause the lever to move on its own and raise the 3 pt?
Loader does leak up or down. 3 pt and loader share same hydraulic pump.
   / 3 pt leaks up & control lever moves as well #2
Check to see if there is a friction disc / tension nut on that model.
I'm not up on the jap compacts ford sold...
soundguy
I'll look at the mechanism a little closer. I just do not remeber seeing a place to tighten the lever.
   / 3 pt leaks up & control lever moves as well #4
The mechanism is for sure different than the old fords.
i grabbed the diagrams from CNH.. the plain 1710 digram don't show much.. the 1710 draft control diagram has more detail.
I see some washers.. so those might be the friction control adjustment... hard to say without a master parts catalog in my hands... and i don't have one for that model.
RickB may know off the top of his head though.
soundguy
   / 3 pt leaks up & control lever moves as well #5
Looks like nut # 35 and 14 adjust washers I think that might be a place to start.
   / 3 pt leaks up & control lever moves as well #6
There is a low and high adjustment for the lever in pic 1 and 2, that should not be your problem. On pic 3 below a bracket where the main control arm rod is and #14 is where you tighten it.
JC,
Thanks guys,
JC, I believe you are talking about that larger nut that is just peeking out from behind the shield/shroud and is against the casing under the seat.
I'll try and tighten that nut when it gets a little warmer outside.
   / 3 pt leaks up & control lever moves as well #8
Thanks guys,
Yes, I did not have a better picture from the side.There are couple of washers behind the nut to adjust the friction. I don't think the nut has to be real tight , just enough for the lever to move solidly without slippage.
JC,
Boom Sprayer (A54865)
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A54865)
New/Unused Gold...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
44029 (A51692)
44029 (A51692)
