Why are my front tires flat all the time!!!
   / Why are my front tires flat all the time!!!
Agree, w-o-r-s-t f-i-s-h e-v-e-r........
Actually a buddy of mine who grew up in La Loche (same level of northern-ness as Fort Mac on the Sask side) grew up eating them. He was raised traditional Dene Cree and they eat them all the time.
I personally can't stand Jackfish. They remind me of alligators - too many teeth and too small a brain!!!
Now pickerel on the other hand.... mmmmmmm.....
-Jer.
   / Why are my front tires flat all the time!!! #43
Is a small slough shark! You can make a little money betting on this !:D
Now a "Walleye" is maybe what you are referring to and is excellent eating.:D
A lot of people mistakenly refer to them as Pickerel and get a little adamant on their terminology. :D
Easy Beer money.:D
   / Why are my front tires flat all the time!!! #44
Sometimes folks get really careful about testing all the rubber of a tire, including the side wall and the valve stem with soap solution BUT do not check the entire surface of the rim/wheel (BOTH SIDES) where porosity, corrosion, or whatever may allow an air leak.
I'm with JJ on the air leak detection. If it looses air fast enough to be flat sitting still overnight it looses air fast enough to see the bubbles. I am not particularly concerned with not testing for a leak under exactly the overnight conditions. I would not be too concerned with the relative expansion and contraction differentials between tire rubber and wheel materials. Can anyone offer evidence of EVER observing that?
You put air in and it leaks out. It is unlikely that it leaks out over a really wide porous area rather than a quite localized spot. The leak will be detectable if you are thorough and careful in your technique.
You could "paint" the whole tire, wheel, and valve stem (including the cap) with rubber cement and hang the tire in the air so no part of it touched ground. Now tell me how the air could get out without blowing up a ballon looking bump in the rubber cement.
Pat
   / Why are my front tires flat all the time!!! #45
The problem and specific detection lies in the temperature at which the leaking occurs.:D
   / Why are my front tires flat all the time!!! #46
Just a thought , is it possible that moisture in the valve stem freezes and pushes the valve off of it's seat a little and deflates the tyre ? Next day at the tyre shop the valve has thawed and shows no leak .
   / Why are my front tires flat all the time!!! #47
A small balloon secured on the valve stem with a rubber band should be able to test out that situation.
   / Why are my front tires flat all the time!!! #48
OK Pat I will give you my example and you can tell me what you think. My fiance bought a new corolla During the spring. A couple of months after she bought it she hit a pothole and bent the rim. It did not lose air so she did not worry about it. She drove that car all summer making trips between my house and tulsa where she lived. She came to visit one weekend in the fall and it turned cold the night she was here. She woke up sunday morning and that tire was completely flat. I aired it up and tested for a leak and it was leaking where the rim was bent. I had some slime so I slimed it to see what happened. It held air with the slime and went to a salvage yard and got a used rim with a fairly new tire on it. we swapped out the tires and rims and kept her bent one for a a full size tire spare. She had that car for a another year and that tire never did lose any air. Now what would be your explanation of a tire running for several months without losing air then the first cold day we have it goes flat overnight. The leak that was found was not a nail but was leaking around the bent rim. I attribute that to the temperature change contracting the rim or the tire enough to lose the seal.
   / Why are my front tires flat all the time!!! #49
I think that the reason for the leak has been stated before, Say you have a bent rim and it holds air at 32 lbs not leaking for a year. It gets cold one night, and the tire pressure is reduced due to cold temp, and it starts to leak. That is sort of logical isn't it. I have aired up tires to 45 lbs, and found no leak, So I let some air out to the stated pressure on the tire, and it started to leak. This is also logical. That same car could have hit a pot hole that day and when night, and cold came, it started to leak. If you want to keep the tire and rim, then I would break it down, clean the rim, and put some tire bead sealant all around.
   / Why are my front tires flat all the time!!! #50
JJ you could be right and as I said before i bought her a good rim and tire and that one was kept for a spare for a while after. My opinion on it is that as the temperature went down the rim and tire contracted at slightly different rates and with the rim being bent that was enough for it to lose air. I wont ever know for sure unless someone has some studies on that issue.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
2004 Ford F-250 Service Truck (A53422)
2004 Ford F-250...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53473)
DeeZee Crossover...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A53843)
2012 HEIL TRAILER...
