Made Some Side Rails For My Trailer
   / Made Some Side Rails For My Trailer #1
hunterridgefarm
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I finally got around to making the side rails for my trailer. I used treated wood and bolted it together.
I made corner brackets out of metal at work to hold the front on. I made it with a two piece rear gate. I did not go the full length of the trailer so I could open the rear gate without droping the ramps.
   / Made Some Side Rails For My Trailer #2
Looks good.
I've often thought about doing something like that with mine.
Are your corners quick connect or screws/bolts ?
   / Made Some Side Rails For My Trailer #3
Nice looking trailer and truck. I really like the brackets you made.
Chris
Looks good.
Brackets are screwed in. I ran out of bolts. I was looking for some heavy hinges with removeable pins but could not find any and did not want to drill the pins out. I can remove the screws on one side of the brackets and lift the sides off.
   / Made Some Side Rails For My Trailer #5
Nice job on the rails and brackets.
I made a set on mine so i can haul 125 bales of hay and don't have
to strap it down, then i take mine off.
But i really like the way you fixed the brackets.
Thanks for sharing
_________________
Bill
   / Made Some Side Rails For My Trailer #6
I picked up some corner brackets from Northern Tools. They had the straights too. They had them in stock back in the trailer section. They work great if you're making the sides removeable.
Thanks for sharing
_________________
Bill
Bill,
Thats one of the reasons I made these. I need to haul some straw to seed the yard. I was unable to get any grass started last year due to the drought.
I also have a lot of things I need to haul that would be hard to strap down but will travel great with the side rails.
David
   / Made Some Side Rails For My Trailer #9
That's what I am starting right now. I got mine at Tractor Supply:
Tractor Supply Company - Carry-On Trailer Left & Right Corner Brackets
My local store had the straights too. I'm just collecting the lumber and brackets now so it will be a few weeks until I'm done (I plan on having it ready for the spring mulch season!)
   / Made Some Side Rails For My Trailer #10
David,
Nice work on build those sides for your trailer.
Dang, you reminded me of another project to do. I've been wanting to do that for a year now. Yours really came out nice.
What are you pulling with?
Thanks,
Rob-
THREE POINT ATTACHMENT (A58214)
THREE POINT...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
AEREATOR (A58214)
AEREATOR (A58214)
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2020 DRAGON ESP...
2018 Chevrolet Camaro 1LT Coupe (A59231)
2018 Chevrolet...
