1533 vs 1540, $1500 diff
   / 1533 vs 1540, $1500 diff #11
Congrats :D
   / 1533 vs 1540, $1500 diff #12
Valorum,
Congratulations! You are going to enjoy that machine very much!
   / 1533 vs 1540, $1500 diff #13
Valorum, Just saw this thread and thought I would congratulate you on your new tractor ...:D I think you picked the right trans
When I got my 1433v I didn't think much about the difference between both transmissions 8x8 or 12x12 and wish I had.. I have the 8x8 with the large tire format and for me "only when mowing" low range 4th gear is too slow and hi range 1st gear is too fast unless you lower rpm's which will slow your blade speed also...finding a happy medium, if you will...
I assume the 12x12 would have a better selection of gears for a more comfortable ground speed when mowing...not to mention a little slower ratio for tilling ground as well.....Just my .02 worth
   / 1533 vs 1540, $1500 diff #14
If you guys with the 8x8 are missing the mid-range that we have with the 12x12, then you really are missing out on the best part. That low range is good for very little. I use the mid and upper ranges almost exclusively.
   / 1533 vs 1540, $1500 diff #15
Congrats on the purchase, I think you would be happy with either machine. I have a 1433 that i am very happy with, i pull a 7' finishing mower with no problem.
Shane
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
