how to heat metal to straighten?
   / how to heat metal to straighten? #11
Here's an article on how to build your own carbon-arc torch. I used rods obtained from an old movie theatre after they throw them away.
Andy
  • Make_a_carbon_arc_torch_for_your_220_volt_stick_we.pdf
   / how to heat metal to straighten? #12
work with ac only boxes?
soundguy
   / how to heat metal to straighten? #13
soundguy
I believe so. I think the carbon rods will "stick" together on DC.
I've never tried mine on DC since I only have AC. I also didn't build mine. I bought it years ago for less that $50 I think. A friend of mine and myself bent and entire exhaust system using one.
Andy
   / how to heat metal to straighten? #14
I may have to try this.. i have a decent size cracker box.. but no DC.. and no real torches.. just small bottles which are almost worthless..
soundguy
   / how to heat metal to straighten? #15
I've used this same rod in a 'carbon air arc' scarfing setup. Almost positive it was DC.
   / how to heat metal to straighten? #16
Let me hijack this: I have the top off of an old wood cookstove, I feel sure it is wroght iron. It is bent, how hot does it have to get to bend back?
   / how to heat metal to straighten? #17
Old wood stoves were generaly made of cast iron. Yours probably warped due to excessive heat. I know of no way to safely straighten warped cast iron. It will probably break on you.
   / how to heat metal to straighten? #18
I agree with all...for light heating and bending.. propane and mapp are ok.. for more.. get a real set of bottles..thanks for this posting..
   / how to heat metal to straighten? #19
Several parts on a disc are bent, such as where the top link attaches. These parts are simple steel flat stock, up to 1/4 inch thick.
I you bent them, then more than just straightening may be required ...sounds like they were under-engineered, at least for the use to which the implement's been put.
Maybe take the implement to the power?... or find a welder who makes house calls with truck w. engine-driven welder ...as required, straighten or cut out weak links and weld in what's required
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
LINDE WELDER (A53843)
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
