Ford 1700 Range Selector stuck
/ Ford 1700 Range Selector stuck #1
darkinark
Today while hauling brush the range selector got stuck and I can't budge it. It appears to be in the neutral position, but when I select a gear with the mainshift lever it drives as if it is in a higher gear. Any thoughts to help? Also, I need a service manual for this tractor, are there any floating around on the web for free? Thanks
/ Ford 1700 Range Selector stuck #2
The question was asked several times before. Look at the link below and you'll find your answer. Let me know what part of the manual you need and I'll email it to you.
JC,
http://www.tractorbynet.com/forums/...700-range-selector.html?highlight=detent+ball
JC,
Thanks JC, I will try that tomorrow. I could use the pages of the manual that show opening up the cover plate. By the schematic posted elsewhere I cannot tell how safe it is to pull it off without any parts moving or falling out of position. I appreciate your help.
/ Ford 1700 Range Selector stuck #4
Darkinark,
You do not need to take the cover plate to take detent spring ball and spring. I'll post the section you asked tomorrow.
JC,
/ Ford 1700 Range Selector stuck #5
Darkinark,
Attached you'll find info requested.
JC,
JC,
Thanks, it is raining here today, so I will wait to try this (hopefully tomorrow). I appreciate the files, they will help alot.
OK, I loosened the bolts, would not budge; took the bolts completely out, would not budge; pulled the springs out, then it moved smoothly into gear. JC, thanks for your help and for the files.
/ Ford 1700 Range Selector stuck #8
Sweet:) Did you check the SS ball for roundness? was it roughed up? in either case I'd change the ball and put it back with the same spring unless spring is damaged.
JC,
No, I didn't check the balls because I couldn't get them out. My son has a magnet that will reach them though and I will check them. Thanks again.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
TANK MANIFOLD (A58214)
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
UNUSED IRANCH 38" MINI LAND LEVELER (A60432)
UNUSED IRANCH 38"...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
