orchard debris/leaf vacuum
   / orchard debris/leaf vacuum #1
StPat
I have an old golf course greens mower, 16hp electric start engine, want to turn it into a pull behind vacuum. Any suggestions as to where I can get the blower/impeller assy? I have no idea what size etc.
Thanks, Patrick
Nobody got any info on impellers for vacuum??
   / orchard debris/leaf vacuum #3
There are some large vacuum/ Blowers out there and here are some links to them.
http://www.toro.com/golf/docs/brochures/db_400_600_800.pdf
Giant-Vac Leaf Blowers
Minuteman Parker Portable Truck Loader 16 HP, 10in x 15ft. Hose, Model# PL09616 | Blowers | Northern Tool + Equipment
I am sure that the impeller can be purchased new (at an inflated cost). I would ask the grounds keeper from a large golf course and ask who services their equipment and hook up with that guy to see if they have any blown engine units, or parts. Or search some on the equipment dealers to see who has blowers/ broken stuff that you could salvage parts from.
Stuart
   / orchard debris/leaf vacuum #4
Others here have reported that most manufacturers are unwilling to sell just impellers and housings to help you build your own. Someone reported that one manufacturer required a serial no. before supplying a replacement impeller.
   / orchard debris/leaf vacuum #5
If you can weld, its easy to make your own. I did a 6 blade impeller replacement and a cage from flat steel. It has VERY high suction and will even pull a brick up from my driveway edging if I'm not careful. Pulled one of my gloves off once when clearing the inlet. Counted all my fingers on that hand afterwards ! The initial problem I had with it was insufficient inlet size, once I went to 12" it worked very well. I attach it to my 6' mower decks (front and a mid mount job). Now the only problem is insufficient trailer capacity. There are several commercially available blowers and suckers that you can adapt for your specific use. TracVac comes to mind. I've seen some versions of this that bolt on to a rotary mower deck that are belt driven, too. Is your mower really a real reel type? My sperience with green's mowers is that of reel cutters. I made an adaptor up for my sucker using a capped piece of 12" dia. PVC pipe that had a 2 inch slit in it to receive the clippings. It worked pretty well on short clippings but plugged with leaves and longer residue. BTW: 12" rubber hose is pretty expensive. I recall paying $10 a foot for the stuff....
   / orchard debris/leaf vacuum #6
Here's long view picture from my camera phone from last fall. This what you are looking for?
Nissan Forklift (A55973)
Nissan Forklift...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
60in Forks (A56857)
60in Forks (A56857)
