Neighbor Fence On My Land
   / Neighbor Fence On My Land #31
This is good information. Property line disputes can be ugly. Forever damaging a relationship with a neighbor. We have just moved to a new place. I have a couple of neighbors fussing at me about property lines. I'll let them figure it out. They seem to have nothing else to do.
   / Neighbor Fence On My Land #32
Good people still exist. The neighbor came over and told me he is going to move his fence, said it was the right thing to do and he acknowledged he should have gotten a good survey before fencing. I was right, he is a nice guy. I offered to help him do the job. Great and inexpensive ending.
Funny how his tune changed so abruptly. Call me a cynic but I bet he changed after he talked to his lawyer;)
   / Neighbor Fence On My Land #33
If you just purchased the place, you should have a current survey and could share that with the neighbor of they are agreeable. I don't think I would let them decide your boundary lines. They are probably worried about softening not right. If you have any concerns about the lines, then do your own measurements.
   / Neighbor Fence On My Land #34
Regardless of the his motivation, you and your neighbor are going to have both a solution to a problem and a good relationship. That is an ideal solution in my book.
Congratulations.
   / Neighbor Fence On My Land #37
You should also have an attorney and surveyor record a new survey and Boundary Agreement at the courthouse, otherwise everything is still verbal and open for another problem in the future.
I do plan on having that line surveyed. There are numerous markers on this line but due to the terrain, I want one more marker on the tip top of the hill. With the fence down though, all will be back the way it should be. He's not sure when he is putting fence back up in correct location.
   / Neighbor Fence On My Land #39
The biggest problem for landowners and boundary disputes or questions regarding boundaries occurs in the original colony states as they are all "meets and bounds" measured. In other words, " from the large oak tree east of the twin forks of Smith creek, go westerly 234 paces to the large granite rock.....", you get the picture. Whereas after it was apparent that this was not a great survey system, the "Government" survey using Section, Township and Range was used and all new states were surveyed as such. The Feds contracted out every Township in every new state with "meridians" identified and measured from that starting point. This system was much easier to work with and much more accurate, certainly at the time most of the surveys were made. Don't forget that the Feds bid all of these surveys out and, you guessed it, the low bidder got the jobs. Some of these surveys are very interesting to say the least. That being said, section corners marked and found are the gospel that modern surveyors must use to calculate any sub-section surveys. Government survey markers are installed and classified to make sure that therre is no movement from that exact location. I feel sorry for, and hate to work in those original colony states as the boundary descriptions are usually very vague. Title companies have gone to so many loop holes that their policies are almost worthless. The registered surveyor has a horrendous chore to adequately survey and put his E&O on the line as they are the ones that will eventually go to court and defend their work in the case of a boundary dispute. I don't envy them.
   / Neighbor Fence On My Land #40
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2017 Versatille 260 (A60462)
2017 Versatille...
2019 GALYEAN...
2022 CATERPILLAR D3 CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
