sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,862
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have an 8 year old Morton 42 by 60 Morton bldg that I might want to insulate. It's on a six inch concrete pad with a vapor barrier and the fiberboard roof "insulaton" to prevent condensation drips. I have two gable end 17 ft sliding doors. It has the truss roof with the high-clearance spacing that gives the base of the truss a shallow "V" effect. I have soffet and roof vents and only a few mice to chew on things.
I am debating insulation and can only figure maybe 2 1/2 inch foam panels in the side walls and maybe 5" or 7 1/2" foam for the ceiling? I figure to just put foam panels over the doors or maybe in insualted blanket for the winter? Toss in a woodstove with a side exit and I'm good to go? I do have 100 gallons of clean waste oil and hydraulic oil per year as well and that could be an option. Fiberglass doesn't sound appealing from a rodent standpoint?
I don't want to heat to 70 degrees but it would be nice to have a warmer place to work for a few weeks or months. What do you think materials would cost?
This is an impulse thing so I have only searched a little and got confused. I would do a first-class job if I do it. Any advice would be appreciated.
