Whitey
Gold Member
I posted a thread awhile ago concerning my JD 7 BH control box and it's apparent need of some work. After consulting the JD parts web page and procuring some new O rings...I started to replace what I thought was the origin of a leak and an easy fix. I was wrong.
As the pictures will show I pulled the entire control box. Not so bad for I always wanted to tear one apart (not that I know what I am doing
) but as you can see I have some metal washers that hold in the O rings at both ends of the spool. All of mine are either bent or cupped?
Called everyone and no one knows if they are to be flat or cupped.....even JD. So my only solution was to order a couple and wait to see how they look. It seems to me they should be flat. I just wondering if anyone would like to weigh in o
n this. One more thing.......new washers (two at each end) are around $3 - $4 a set times twelve that is why I only ordered two........also when I took them out......the concave side was down?????
