I have a b2400 with LA352 loader with a Husco 9210 2-spool valve.  The spool that controls the loader arm has a float position.  I'd like to use the float position with the cylinders that control the bucket.  So I switched the hydraulic lines going into the work ports.  I expected the controls to be reversed and the float position would now control the bucket not the loader arms.  Well, that's what happened except now the loader arm moves up when it should should be going up and when it should be going down.
Why would it go up when it should be going down? What do I not understand about the valve that would cause this. Thank for your help in advance.
