Help with ID on Disc Hiller
   / Help with ID on Disc Hiller #1
clenhart
South Louisiana
Kubota L3400 HST
I have an old disc hiller (row maker?) that has worked great until yesterday. After making rows in the garden, I noticed that one of the bearing housings was broken. On further inspection it appears that it is cast iron and that one side has been cracked for a while and finally broke completely thru. The bearings are still good and it turns freely, but I need to find a replacement bearing assembly for the side that is broken. Due to the age of the implement and surface rust I cannot ID the manufacturer. Any help with ID or info on where to pursue replacement parts would be greatly appreciated.
Thanks
Btt
Still hoping someone can ID this hiller... :)
   / Help with ID on Disc Hiller #3
Can not identify it but you could take it apart... then take the broken pieces to a welding shop.
Cast is tricky to weld up, but it can be done. KennyV.
   / Help with ID on Disc Hiller #4
you may have to replace the whole assembly, luckily you should be able to find something that will fit a standard tool bar. unfortunately they aren't cheap.
Thanks for the input... I think I will attempt to weld it, since I don't have anything to lose, and if that doesn't work I'll look for replacement parts. I have never welded cast iron before, but there is a first time for everything.
:D
I was able to weld the cast bearing housing using a Mig welder. I kept the heat down, welded in small increments, and allowed to cool slowly. Worked like a charm... :D
   / Help with ID on Disc Hiller #8
what... no pictures?:D
   / Help with ID on Disc Hiller #9
This hiller was made originally by the King Plow Company, now known as W & A manufacturing, in Pine Bluff AK. They have a website. However, I believe that exact hiller has been discontinued. They may still have castings though.
Thanks for the info. I figured that sooner or later someone would recognize it.
Chip
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2006 International 4400 LP Ambulance (A50323)
2006 International...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
