Site Prep--Where to start?
   / Site Prep--Where to start? #1
TigerfaninAR
Gold Member
Central Arkansas
Kubota B2320 FEL, MMM
Last Fall we bought 7 acres. We bought the last two lots at the end of a cul de sac. We knew going in it was somewhat low and would require some dirt work etc. The price reflected this. The general slop is from left to right in the pictures below. As you can see there is no ditch in the pictures but all neighbors have a ditch (to the left in the picture). Also a very general slope from front to back. So we get all the water coming down from the ditch/road and then it just spreads all into the front. I've asked some contractor friends and they say whoever does the initial dirt work would be able to see what is needed and do it. This is going to be our forever home and seems to me we need some sort of engineer for plans etc. In no way shape or form do I want to wing it. Not worried about the money when it comes to this. Are the guys who do the initial work qualified to make decisions about a ditch, slope from and to the house? Is there a specialized engineer who handles these things?
First picture is the property line at left looking from the street (where the grass is cut). Second is the middle and right of the property.
   / Site Prep--Where to start? #2
Looks like a very nice lot. From your initial statement sounded like it was
really rough lot. From pictures provided any good dirt contractors they could
handled the job.Are you can hire site engineer to set elevation marks on your
site if cant find good contractor. Framer
   / Site Prep--Where to start? #3
I will just suggest that whatever you do, do NOT build across the lot line. Either get the two lots replatted as a single lot or build clear of the line. This will save you headaches with taxing authorities and any later sales. I also suggest you get an engineer to do a study and make suggestions, especially if you don't feel comfortable doing this yourself. If you use a home builder or excavator, you may find they have their own interests at heart rather than yours. I think money spent with a civil engineer will serve you well in the long run. A land surveyor in your area may be able to suggest someone.
EDIT: That's a beautiful setting for a home. I think you've done well.
As you said, I have been told by most to build everything on one lot. Luckily with our current plans this works out perfectly. Your thought on the engineer is what I was thinking. We plan to self-contract and this is the only area where we don't know someone in this line of work. Thanks for your reply.
   / Site Prep--Where to start? #5
who ever you pick to do the job make sure they SAVE THE TOPSOIL
   / Site Prep--Where to start? #6
I had 3 Civil Engineer's give quotes for laying out a 1/3rd acre industrial lot I had and the best one was $15000.
Not sure how that compares to residential.
Warhammer
   / Site Prep--Where to start? #7
With the economy the way that it is my guess is that you could probably get the assistance of a professional engineer at a reasonable rate. It is probably worth looking into.
   / Site Prep--Where to start? #8
I would have my house prints done first in relation to lot elevations.Like for
driveway,basement view out or walk out. Then contractors would know how
to grad your lot.Framer
   / Site Prep--Where to start? #9
A couple things to consider. Well and septic. There are restrictions on how far they have to be apart, here it is 100ft from drainfield to well. Where is the outlet planned for the house. Do you have enough fall from the bathroom and such to the tank. Are they going to make you put in a raised system?
When they talk elevations, this comes into play. I once came upon a foundation that was dug and they were about ready to bring in the home, prefab. I asked, where is the septic tank going? right there! Nice, looks to me as it will need to be about a foot above the toilet seat. Job stopped on the spot and two ft were added to the footing.
Another thing you might want to consider is outbuildings. When putting in the water and electricity, put a tee on the line for future hookups, and when installing the breaker box, have them drop a conduit so you can run a line outside without having to tear up a wall to get to the box.
You might get the inspector out and get to know him/her, show him what you have in mind before you go at it. Always good to ask questions, he will point you in the right direction.
Once you have the elevations and have been educated a bit, you will feel much more confident to show the dirt herders what you need.
If you have a standing water problem, rent a level or lazer and do some elevations and get a feel for your place. If you take some stakes and layout the house, septic fields, roads and all, it will help you a lot.
Have fun, building can be a nightmare, just get good people to help you.
measure twice, cut once.
Very nice lot piece you have there.
   / Site Prep--Where to start? #10
My building site was different from yours in that it was very hilly. Yours is nearly level, and has subtle slopes.
The first thing I would do is buy one of these Stanley Pocket Hand Level — Model# PL1 | Laser Levels | Northern Tool + Equipment , which is the fastest, easiest grade estimator I have ever used.
Measure how high your eye is, and get a couple of tall stakes and some way to mark them at the height of your eye, and in a day you will know more about the slope of your land than you will learn in a week with a rotary laser level.
Rough out where you want the house, the septic, etc. , then call in an engineer and get him to confirm what you want.
I have a rotary laser that is good to 1/4" in 100 yards. It is great for building foundations, footers, pools, water features and things that require that accuracy.
The pocket level is good to a few inches in 100 yards, but it is a lot faster and doesn't wash out in sunlight.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
