Cub Cadet 6284 - yes or no?
   / Cub Cadet 6284 - yes or no? #1
jnelson
Southwestern Michigan
Cub Cadet 6284
I have been looking at purchasing a 4 x 4 diesel CUT for some time. I have come across several opportunities to purchase new or very low hour CC 6284 models at what appear to be very attractive prices. I have tried to research this model and have found some good reviews, but I am concerned by a number of reviews referring to problems with the transmission portion of the drive train (nobody has had anything bad to say about the 28 HP Perkins engine).
I know that CC has changed their models to Yanmar produced tractors and they wanted to clear out existing models, but are these 6284's priced so low because of this or because they are a pig in a poke? I'm hoping people out there can provide me with enough information that I can either feel comfortable about taking advantage of what appears to be great deals or warn me off before I make an expensive mistake. I plan to use this on our 40 acre place mostly for mowing and clearing snow, but I may eventually install a FEL and utilize 3 point implements - nothing real heavy and no commercial use.
I am a bit concerned that there seems to be no way of contacting CC (now part of MTD) to inquire about warranty and service issues. Does it make sense to purchase a product from a company not even willing to provide direct contact information to current and/or potential customers? Their website appears useless if someone has serious service or warranty questions or issues - kind of scary enough in itself to warn me off. I know that there are very good and service oriented CC dealers out there, but I wonder how well the 6284 (and other CC models) are being supported to them by the factory?
Thanks!
jnelson
   / Cub Cadet 6284 - yes or no? #2
What kind of deal is it? Whats with it? You will have a hard time to find a loader and mounting brackets.
I have found several new or very low hour units. One new one without any add-ons is $7,000.00 though it was sold to the current seller at a liquidation auction so it is doubtful that there would be any warranty with it. Another new one I found with FEL (also likely without warranty) is $10,000. I have also found several used low hour units with implements such as mower, tiller, etc in the $6,500 range.
You raise a good point about the loader and I appreciate it. Sounds like if I think I will need a loader at any point in the future then it would be very wise to get it with the tractor. Any other advice?
I'm not concerned about resale value as some people like to talk about since I plan to keep and use the tractor for a very long time. I also understand that any tractor is apt to have little problems. I am handy and can service the little things. The thing I worry about is a major powertrain problem. It appears that the engine side of things (a Perkins 28 HP) is rock solid, so that narrows it down to the hydro trans and differentials.
I am kind of thinking at the prices I mentioned above for a 4x4 28 hp diesel one could do far worse with one of the Chinese models sold at farm stores. I'm probably overly cautious about this as I have never spent this type of money before. My biggest investment to date has been of the lawn tractor (Murray) variety, but I am tired of the throw-aways that keep wearing out. Again, I am very unimpressed with the MTD website and their way of supporting (or not) a (supposedly) high-line compact tractor.
Jnelson
   / Cub Cadet 6284 - yes or no? #4
I dont want to discourage you but I have taken apart many of those trannies and parts are very expensive. Have had some no problems but if it was me I would spend a little more on the new yanmar model.
   / Cub Cadet 6284 - yes or no? #5
*I'm not concerned about resale value as some people like to talk about since I plan to keep and use the tractor for a very long time.
Jnelson
This makes sense but how do you know something won't come up 10 to 15 years down the line that will cause you to have to sell. :)
I really appreciate your input. What manufacturer makes that transmission? Is it shared with other makes and/or models? Is there a particular failure that they are prone to? I have to conclude from your reply that you consider the transmission as the weak line to this model. Are the problems you are seeing mostly related to commercial use?
I did finally locate a way to contact factory customer service and the person I spoke to was very helpful. He searched for service bulletins and recalls on this model (even narrowing it by serial number) and found two. The first involved an upgrade model fluid filter for the hydraulic system. The second was a housing and reverse filter upgrade for the transmission.
I would love to "spend a little more" but in this case that equates to $7,000 more which puts it way outside my budget. This is the first time I have found a tractor in this class in new or near new condition in this price range. There would be no warranty protection on one of these almost new tractors, so it appears the big risk here is related to potential transmission problems. Do you think that the lighter use I would be subjecting the tractor to would lessen the chances that problems might occur?
Jnelson
True, but would the $7,000 difference now still be that much then? And if those 10 to 15 years consisted of good, reliable service I don't think I would complain. The bigger issue at this stage is affordability. Since I am basically looking at this tractor for mowing a very large lawn and hobby farm use I am not able to justify the same cash outlay as those that rely on their equipment for their living.
Would you agree that purchasing a tractor a little larger than I might otherwise afford (28 HP) beats purchasing a better brand in the 18 - 24 HP range? Again, I realize reliability counts, but that aside what do you think?
Jnelson
   / Cub Cadet 6284 - yes or no? #8
Jnelson
Good counter point.:)
Don't get me wrong - I greatly appreciate you guys giving your input. I have to remember that priorities have a strong bearing on opinions and decisions like this. Reliability is important to me, but I can't say it directly affects my livelihood.
Would you agree that if someone purchases one of these tractors priced this low and if it works reliably, then it would be a very good value in terms of the amount of tractor per dollar? If the answer is yes, then the wild card here is what are the chances that there would be a major problem? One could also say that the initial cost savings could still be more than a repair bill, but then who wants that hassle?
I guess at the end of the day it's like the guy with the big gun says, "do you feel lucky, punk?" I'll let you know what I decide. Frankly with the economy in the dumps I have to consider if I should do anything right now, but the spring weather is coming and it sure would be handy to have a shiny new CUT. :confused:
Jnelson
   / Cub Cadet 6284 - yes or no? #10
Jnelson -
I have used Cub products for the last 14 years, currently own 3 Cub CUT's, (including a 6284) , have a good friend that's a Cub dealer, and buy/sell Cub tractors and equipment as a hobby.... so I'm very familiar with the older 5000/6000/7000/8000 series cubs.
You sound very informed, and raise some good points.
The transmission issue; the 5000 series Cubs had some issues when they were first introduced, they are not as beefy as they could/should be. Unfortunately, this problem stuck with Cub and hurt their reputation....
The 6000 series trannies are much beefier, and I have not read/heard about any problems. The tractor is essentially the same size as a 5000, but with bigger tires, and heavier tranny, it weighs 600 lbs more than the 5000 series. I worked mine fairly hard a few months back moving brush/logs/dirt, and it worked great. The only downside to my 6284 thus far is it doesn't like the cold, so you have to warm it up before operating.
Loader issue; there are still loaders out there. I know of one for sale right now, brand new, at a MI dealer for around 3K. They are the same loader as the 5000 series, model 612, but higher lift capacity.
You are correct, Cub had a "fire sale" to clear inventory on all the older Cubs to make way for the new Cub-Yanmars. (By the way, I have no experience with, but hear nothing but positive things)
Warranties; If you can find a new leftover, it should have a warranty. Many of the used ones were sold at auction, thus no warranty. My new 2007 5234 series was purchased at an auction, no warranty...but I'm using it as my mower/blower/blade tractor, so far no problems at all. I use my 6000 and 7500 series for loader work.
Sorry for the long-winded response, if you want any more info let me know!
2011 COMPTANK ACID TRANSPORT TRAILER (A55745)
2011 COMPTANK ACID...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
