3-Point Hitch MB265B 3 Point hitch will not raise
   / MB265B 3 Point hitch will not raise #1
stumpfield
Gold Member
Sierra Foothills
2005 MT265B
I got the equivalent of a 1533 (challenger MB265B). Never had a problem before. I parked the tractor for about a week. Now suddenly the 3 Point hitch will not raise. The front loader and all other hydraulic functions worked fine including the top and tilt. Any suggestion on where to look for potential problem? Thanks
   / MB265B 3 Point hitch will not raise #2
Do not know your tractor but does it have a valve under the seat to adjust the 3 pth? Many do. Is it possible someone played with it since you last used it and screw it in where the lift will not work?
   / MB265B 3 Point hitch will not raise #3
Not sure what set up you have, but it could just be a quick coupler hanging up.
   / MB265B 3 Point hitch will not raise #4
stumpfield- I thought for sure I broke something on my GC2310 when the 3PH wouldn't move, but kthompson's correct-- if that knob is screwed all the way in, the 3PH control won't do anything.
The knob's purpose is to control the speed at which the 3PH drops, with a "lock" position if it's screwed in (clockwise) all the way, like a faucet....
It's the knob on the left in the photo; the other one is for adjusting mower deck height. Maybe?
I have a similar knob. I turned it both directions but didn't make any difference. Today, I try it again then it suddenly works! I was able to raise the 3PH just once.:mad: After that it stop working again. I tried looking around to see if anything stuck but no luck. Any sugguestion on where to look specifically? Thanks.
There's a knob under the seat. I turned it back and forth but no help. I'm pretty sure no one plays with the tractor. It was working fine the last time I move the tractor. I have my boxblade on all the time so each time I move the tractor, I have to raise the 3PH.
   / MB265B 3 Point hitch will not raise #7
Try turning knob counter-clockwise to open valve, leave it that way, then allow tractor to run for a while; perhaps there was not much fluid and/or pressure in the system? Maybe you opened the valve, some pressure/fluid got in, and then you closed it again which allowed it to work only a bit? I'm really just guessing here, but it seems to me that it took several minutes for stuff to start working again after I changed the hydraulic fuid, too.
   / MB265B 3 Point hitch will not raise #8
Here are some possible causes from the service manual for a MF 1433 (Agco ST35):
Lift does not rise.
Insufficient engine speed
Insuficient transmission oil
Air leak through suction piping
Clogged suction filter
Maladjusted relief valve
Stuck sequential valve spool
Broken control valve
Broken slow-return check valve
Anyone know if the 3PH uses the same fluid as the rest of the hydraulic system. My loader, top and tilt all seem to work fine. I was able to raise the boxscraper about an inch off the ground to move the tractor using the top/tilt. Should I go ahead and change the hydraulic filter and fluid to see if it helps? Thanks.
   / MB265B 3 Point hitch will not raise #10
stumpfield-- on my 2310 (with hydrostatic transmission), all hydraulic fluid is the same system- for drive, FEL, and 3PH; all the same except for front axle.... I'm running out of ideas, but jhwentworth's checklist sounds like a good way to go- all control linkages seem OK?
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A55973)
Okada OKB 304B...
207277 (A52708)
207277 (A52708)
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
LIMA MAC 30KW GENERATOR (A58216)
LIMA MAC 30KW...
