Want to lower deck on trailer
   / Want to lower deck on trailer #1
Yankee Clipper
Gold Member
Western US
Hi all,
I bought a car trailer with built with trailer house axles that are mounted on the bottom side of the spring. I have measured and can flip the axles 180 to put them on the inside face of the spring - still have adequate room to axle it to flex etc. This will lower my deck height to where is does not take a high kick or a ladder to get on it.
My question is - since the brake adjuster is on the bottom of the backing plate, do I need to turn them over once once axle is rotated to keep them on the bottom? I am not that tuned in to trailer brakes and don't know all the quirks.
Thanks in advance for your help.
YC
   / Want to lower deck on trailer #2
The brakes adjuster needs to be on the bottom and there are a left side and right side brake assembly. They should be marked as so. Make sure whatever you do you get the brakes back on the right side or they will tear themselves apart the first time you use them.
The other problem you may have is most axles have a bow in them from the factory so that when a load is applied it will make the wheels stay perpendicular to the ground. So actually when there is not load the tires are riding at a slight angle to perpendicular, maybe 3-5%. So flipping them over will cause sever tire ware.
Chris
   / Want to lower deck on trailer #3
Chris,
I have never heard that. You may be right, I will have to go and check some axles that I was saving. What will that affect the camber. I know that you can tune axles by heating the axles in a certain position to correct for camber and or toe-in-out. I have also seen tires on trailers wear like you said.
   / Want to lower deck on trailer #4
Hi all,
YC
I'm wanting a tilt bed .
This way the hight would not mater as much i wouldn't think. .
   / Want to lower deck on trailer #5
Chris is right about the axle bow. I cut the spring saddles off and put them on the bottom of the axles, bolted everything in place and re welded. It was really pretty easy to do.
Dan
Thanks to all who helped -I knew it couldn't be as straight forward as I had thought.
Better leave well enough alone.
   / Want to lower deck on trailer #7
"Flip" is a misnomer that got started in the RV world I believe. Dexter sells kits to move axles to the other side of the spring pack, be it lower or higher. I'm not sure they make them for mobile home axles but they do for many of their popular axles.
http://i.b5z.net/i/u/1080235/f/Trailer_Height_Adjustment.pdf
   / Want to lower deck on trailer #9
I'm thinking the height would not be as much of a concern with a tilt bed as it would be with ramps.
Anybody else?
Agree
Disagree
   / Want to lower deck on trailer #10
Anybody else?
Agree
Disagree
I think bed height still makes a diffenence on a tilt bed as well as bed legnth. My first attempt at building one was about 8' long and about 30" tall. You couldn't drive up it but you could dump stuff off. I made my next trailer with a flipped mobil home axle. It has a 10' bed and 19" deck height. I am able to drive right up unless the deck is wet. If I were to build another it would be 11 or 12' long. 10' is some times kind of short when you need to transfer enough weight past the pivot point to make it flip down. The only way a person could go lower would be to use dropped spindle axles. I have those on my stock trailer. It has about 16" deck height with 7K axles and 16" tires. I have put my JD3320 in it by just backing in to a ditch.
Dan
1995 CATERPILLAR 928F WHEEL LOADER (A52707)
1995 CATERPILLAR...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
More info coming soon! (A55851)
More info coming...
2015 Jeep Compass Latitude SUV (A53424)
2015 Jeep Compass...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2015 DRAGON 130...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
