What are some bx tractors owners logged hours
   / What are some bx tractors owners logged hours #1
taos
canada
kubota b2920
I was wondering what kind of hours a bx tractor owner could expect with proper maintenance?
   / What are some bx tractors owners logged hours #3
taos,
Donno. I'm at 1190 or so. I'll try to let TBN know how it turns out after I've crossed the River Jordan.
I'm not an expert, but I understand a diesel will last & last with proper maintenance. Understand that things break & need fixing/replacing - - I've had 4 or 5 hydraulic lines fail & had to have new ones made. Not to mention stuff I let go & don't repair, like lenses on tail/turn lights.
Obviously, with use, as the machine gets older, more components are going to wear out & need to be replaced. Same as with a car, except most cars are not diesels.
Jack
   / What are some bx tractors owners logged hours #4
Im at above 1300. Heavy usage. Light on maintenance. Everything operating fine.
larry
   / What are some bx tractors owners logged hours #5
I have 1245 hours on mine. I have had to replace the power steering hoses (4), replaced the air filter bracket, the fuel gauge sending unit, and the linkage rod that runs from the 3pt hitch to the MMM. Oh, and a few taillights due to operator error! That's it.
I expect many more hours, unless I trade for a bigger tractor- I now own more land.
Will
   / What are some bx tractors owners logged hours #6
Will
I must be the low hours guy.
BX23 1148
BX1500 422
BX1500 68
   / What are some bx tractors owners logged hours #7
236 honest hours. Pretty hard working in each and every one. One single issue with MMM linkage to to really poor user adjustment. Was sent home from dealer with instruction NOT to touch or adjust MMM linkage. 50 hour, 100 hour, and 200 hour complete (full fluid) dealer services. Headlight switch serviced. Rear left marker bulb replaced. Tightened driver's side rear wheel weight. Hit zerks with grease as often as I have 2 hours to myself...about twice a year. Waxed hood. Twice.
Other than that, she purrs like a kitten and runs like a dream. Figure I'll have a problem with it someday, but I have no idea what. Built like a tank.
Will probably never have more land, but won't sell unless I move into an apartment. or one of my kid's homes. Have 35+ years before I have to worry about that [knocking on side of head].
I am a new bx 25 owner(16 hours) and tought it would be great to here what kind of hours people are putting on there machines, I'm a honda tech with 30years in the trade , and have seen things wear out on these honda cars, (like clock work)(all things wear out) and it's always good to know what (might) fail on these tractors ahead of time.and to hear some of the stories of what was replaced. thanks ,good to here from you all !
   / What are some bx tractors owners logged hours #9
Tractors aren't as bad about that as cars.
   / What are some bx tractors owners logged hours #10
My BX2200 has 735 hours.
So far, I need a new air filter bracket, but I will likely do my own thing here.
Also, both front axles sides drip oil. The drip is coming from the vertical part right beside the tire. This part articulates to actually allow the steering to happen.
(Item 50 in the pic).
Also, I replaced a loader hose and all the quick connects on the loader because they started leaking.
That's about it!
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
