Battle of the pear cactus...
   / Battle of the pear cactus... #11
I agree with the mechaincal removal.
if you mow it, disc it, or till it.. you will just propogate it.
i have 13ac.. it had sporadic cactus on it when we got it.
On the weekends the wife and I walked the property .. each with a 35g trash can, gloves, and a small spade and 3-tine garden rake... pulled out each piece individually and then put inthe burn pit.
no cactus now.
all the big fields with cactus i see that mow them.. just have more cactus the next year.
soundguy
   / Battle of the pear cactus... #12
TexasJohn, I certainly appreciate your advice, and even though I have probably already read the articles you suggest, I will go back and red them again.... (BTW, I'm fairly close to you.... I spend my week at home in Liberty Hill... my money and my weekends are spent in Lampasas)
I suspect that I will end up trying DrRick's suggestion... This property has been neglected for many, many years and the P.Pear had taken over... It is certainly time consuming but I feel I am making good progress by scraping and burning... Thank God it's finally begun to rain in Central Texas which will make getting the pear out by the roots that much easier. Coastal huh? Hmmm <evilgrin>
The Dougster, from the Great Republic of Texas :)
   / Battle of the pear cactus... #13
Lime amendment is another 'long-term' remedy for cactus... they don't like the soil once you amend the ph.
lampassas you say?
I have a friend who lives there.. i went over last easter and bought a ford 951 narrow front tractor from him.
did a 19.5hr red eye trip up, and then short turnaround and back !
soundguy
   / Battle of the pear cactus... #14
Lime amendment huh? Lime is cheap enough, I'll give it a try...
Yes Sir, Lampasas.... actually about half-way between Lampasas and Lometa..... That was quite a trip. I hope you enjoyed it... It finally began to rain here in Cen. Texas... I just had a phone call from a neighbor reporting 2.7-inches... Folks are probably dancing in the streets today.. :D
   / Battle of the pear cactus... #15
Tordon 22 will work and I usually poke it with something first. I use a manure fork for holes.
I'm not someone who likes to use a lot of chemicals but spot spraying doesn't bother me.
If you use mechanical means be careful of the little hairy spines at the base of the big spines. Those little hairy spines get in everything and are much worse than the big ones.
Soundguy, I bet you had to throw those gloves away.
   / Battle of the pear cactus... #16
You bet i did. I also used an inner set of gloves.. those kind witht he rubber on them.. tight form fitting.. over those I used regular 2$ a pair leather 'work' gloves.
they were covered with those lil hairy prongs.. and yeah.. i tosse dthem into the burn pit with the last load of cacti.. those lil ones would work into the leather!
soundguy
   / Battle of the pear cactus... #18
It's amazing how close some of us are. My 25ac are just outside Lampasas on CR2200.
   / Battle of the pear cactus... #19
I use Grazon P+D sprayed onto cactus & yucca. Total kill in one season. East Lampasas County checking in, off FM 2527.
KB
Thanks, guys....this Tordon 22, is this chemical something that requires a license to buy?
2011 Nissan Altima Sedan (A48082)
2011 Nissan Altima...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
UNUSED Woven Landscape Fabric Squares (A50860)
UNUSED Woven...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
