Snow Attachments snow blower in heavy snow
   / snow blower in heavy snow
the fan is driven right off the pto shaft so the fan is spinning 540 rpm. I think i am going to move the fan farther back in the housing. I looked and had around 1/2 inch of gap between the fan and the back of the housing. on the side of the housing there is probably about 3/8" of gap, but the housing is not perfectly round so it goes from about 1/4 to a little over 3/8. i may add some rivet some rubber to the ends of the paddles so they sort of squeegie the inside of the housing or at least get closer.
   / snow blower in heavy snow #12
Mike, I just bought the same blower. The chain on the left side as you look at the augers. It is very robust and heavy. Like you I repainted it, replaced the chains - readjusted, etc.. It looks like you did a complete teardown and did a wonderful job. Now for my question: Did you get it to work properly? I am very concerned as I have no way to test mine until next winter. It looks like mine was well used so it must have satisfied someone but geez, after hearing your 3 feet throw job I am a little concerned.
   / snow blower in heavy snow #13
In post #10 Dave says an easy way to check is if the fan turns the same speed as the PTO. Post #11 Mike says its spinning at 540 RPM the same as the PTO.
Does Daves post mean a blower fan that turns the same as the PTO is a 1000 PTO RPM unit or a 540 RPM unit. If it means a 1000 RPM blower fan turns 1:1 with the PTO then Mike's 540 RPM PTO speed is too slow.
Yeah the snow i was blowing was very wet, the next day , i then set the fan further back in the housing and tried some more wet snow and i probably got about 10 feet out of it. i also sprayed some silicone on the fan and chute and i am sure that helped out too.
Cdcole,
Send me a PM if you need any info or where to get some parts. I usually buy everything i need from surplus center like a lot of other people on this site.
i also think that the curtis gearbox is a little light for the unit
https://www.surpluscenter.com/item.asp?UID=2009050320352012&item=1324&catname=powerTrans
if you look at this page it has a chart and i figure that the gearbox is going maybe 200 rpm and it says that the gearbox will only handle about 6 HP at this rpm which is pretty low, so i always find the cheapest chinese bolts i can find to use as shear pins.
   / snow blower in heavy snow #16
1:1 on blowers usually means its a 540 RPM input...I know all the blowers in the 48-80" range are pretty much only 540 input...I havent seen a blower in that size range yet that wasnt 540.
   / snow blower in heavy snow #17
Thanks for straightening that out Dave. I was confused as to which snowblower fits a 1:1 rotation.
   / snow blower in heavy snow #18
Mike, I think the gearbox HP is ok. The bulk of the HP is consumed on the blower right? You would know better because you have actually used yours!
   / snow blower in heavy snow #19
Mike194-- in my experiences with a walk-behind, the single most important factor behind throwing distance (other than a stretched belt) was clearance between the impeller blade tips and the inside of the round fan housing. Just a little "extra" clearance will decimate throwing distance. Check to see if the impeller blades have been bent from rocks-- that'll do it every time!
You might want to look for clearance specs on your blower, but I doubt that it should exceed 1/4". Nice refinishing job!
Oh-- and a really dumb question.... I suppose you verified direction of fan rotation? Looks like it should be clockwise as you face it from the rear....:eek:
   / snow blower in heavy snow #20
I just bought a George White & Son 87-Super Blizzard. I've tried to locate the mfg. but I guess their no longer in business. We had about 5" of snow and I used it and was very disappointed in the way it performed. It was a better plow than a Snow Blower. I'm using a 60 hp. tractor. I would like to know if anyone knows how many rpm this should run at. Thanks for any help you can give me..
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2020 Case 5550 Trident (A55315)
2020 Case 5550...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
