New JD110TLB almost wasn't big enough
   / New JD110TLB almost wasn't big enough #1
skidoo
Gold Member
Montana - Growing Zone 5
JD 2520, JD X749, JD110TLB
One of my first significant projects for the 110 included prep for re-doing some concrete. Part of that is to remove a big chunk of existing concrete. I did not want to require it be broken in order to move it. Anyway, I couldn't lift it directly with the forks, but with a chain and moving the center of mass closer, it was able to lift it enough to drag it where I wanted. I think the 110 has a few more lbs of lift capacity in the loader than the 4520 that I was originally considering. This time, every bit of capacity was needed. I don't think anything less would have managed. Any idea how much this concrete probably weighed? This was as high as it would go...
   / New JD110TLB almost wasn't big enough #2
Nice pics, no doubt you had quite a load. I am often in same boat needing just a littttllle more tractor for some of my side jobs. I'd would guess ~ 2500# just by the photo its hard to tell..
While demo'ing a large slab last year this is all my FEL wanted:
I recently moved a 500 gallon concrete septic holding tank, no pics I drug it part of the way but got the job done non the less...
   / New JD110TLB almost wasn't big enough #3
I tried to move some 2400# pieces a year or more ago and couldn't. But, the terrain was a lot less level that what you had and I didn't get as good a geometry for the lift/drag.
The other thing going against me was they were in my neighbors yard and he & his son were out there trying to help me, but they knew very little about rigging and a lot about standing in very dangerous places.
My guess is that piece is 2400+ pounds.
   / New JD110TLB almost wasn't big enough #4
Whoa... that's alot of rock, there! That probably weighs as much as your 2520! :D
I was moving pallets of landscaping blocks last Spring when I tied into one that; even at 2,000 rpm the FEL went straight into relief! If the loader won't pick it up... it'll let you know.
Thanks for the pics.
AKfish
   / New JD110TLB almost wasn't big enough #5
I use my dads new Johndeere CT322 compact track skidsteer to move the heavy stuff. It has a tipping load of 6000+ lbs making it easy to move stuff that large. Last night, I moved some 500 to 1000lbs boulders around the ranch. The CT322 picked them up thike they were feathers. I also heared that Johndeere came out with the CT315 for smaller jobs in tight quarters. Nice little machines. I do favor the CT332 because of the power you feel when you get in the machine. Good luck with your new 110! I have heard that is is like the 3720. Is that true?
   / New JD110TLB almost wasn't big enough #6
:)Alls ya had to do was dig out the x700.:D
Jes kiden;)
2015 PETERBILT 367 (A53843)
2015 PETERBILT 367...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
