60" vs 72" finish deck
   / 60" vs 72" finish deck #1
jnelson
Southwestern Michigan
Cub Cadet 6284
I just purchased a 6284 Cud Cadet CUT 4 x 4 with 28 HP Perkins diesel engine and hydro. I now need to purchase a 3 point finish mower to use with it. I am undecided between a 60" and a 72" deck. Some 72" deck literature recommends them for tractors between 30 and 45 HP. Is it possible that a 72" would be too much for my 28 HP tractor?
I understand that the 72" mower would also be more unwieldy in tight areas and of course the 12" wider deck should mow more area faster where tight maneuvering and I will need to consider these factors as well. Right now though I am concerned about the 28 HP with 72" deck.
Since I have not owned a diesel tractor or finish mower before any experience and advice you can share with me will be appreciated.
Thanks!
jnelson
   / 60" vs 72" finish deck #2
I had a 60" King Kutter. It was a POS. Broke every other time I used it. Paid $1100 and spent another $800 in parts over 3 years. I keep all the receipts. Anyway got a Caroni Rear Discharge 72" mower last year and used it all summer with not one break down. Did lose one bolt on the belt cover but probably my fault because I had check the belts the day before for tension and figure I forgot to torque it down.
Back to your question. I run both with zero issues and really can not tell a difference behind a 28 HP Jinma with 25 PTO HP.
Chris
   / 60" vs 72" finish deck #3
I might be able to help since I have a similar size tractor and I have owned both a 60" and a 72" rear finish mower. I have a 29 HP Kubota L2800 and about 2 years ago a friend let me borrow his Bush Hog RDTH72 rear discharge finish mower. I have about 2.5 acres of grass to cut and a good many trees plus a few hills to get up and down. I used his for all one summer until he needed it back and luck was with me as my local dealer was closing out some of last years stock and had a Bush Hog RDTH 60 on sale for $1200 which is a steal.
I have now been using the 60" for a year and really like it. It is somewhat lighter than the 6' which my CUT handles better. The anti scalping wheel in the front works better on the smaller one and I can not really tell the mowing time difference. Of course the smaller one is more maneuverable around trees. You did not say how many acres you are mowing but unless it is more than a couple the 5' finish mower will be fine. If you are mowing 4 or 5 acres the extra foot will be nice. Hope this helps.
   / 60" vs 72" finish deck #4
When we got our DX25 they said it was too small for a 6' mower. We have our 35hp now and we are good to go for a 6'. Same thing with our old Ford 9N, a 5' was the best we could do.
   / 60" vs 72" finish deck #5
I have a Agco St30x which has about 28.5 engine horsepower. I use a 84" finish mower behind it and do not have any issue with horsepower. but I only use it only on the lawn grass, I have a rotary brush mower for the longer stuff. and my wife usually drives behind me in a smaller riding mower that goes around the tree's. it is hard to go around anything but it does the open area's very fast. My vote would be for a 72" heck you can buy a 60" mower on them piles of junk at home depot.
   / 60" vs 72" finish deck #6
Thanks!
I have a Kubota B7800 with 30 HP and I use a 72" RFM to mow ten acres. It handles this mower easily. What has to be taken in to consideration is the weight of these mowers on the three point. My PRD7200 weighs 720#. A 72" RFM of any flavor is a pretty good size hunk o' metal. My yard is flat as a pancake and I probably raise and lower this mower less than six times while mowing. If my yard was hilly I think the 720# weight of this mower would make the tractor unstable if the mower was raised on a side hill. The mowing time saved for a 72" mower over a 60" mower is significant. But so is the weight.
I didn't know that some Cub Cadets came with a Perkins diesel. I have had an Oliver OC-3 track loader with a Perkins gas motor and a MF135 with a Perkins diesel motor. I consider a Perkins motor as one of the very best ever made.
jnelson[/QUOTE
   / 60" vs 72" finish deck #7
Whistlepig brings up a very good point, my tractor is able to lift the 84" unit but i rarely ever even hook up the toplink when mowing. i rarely have a reason to pick up the mower. if it has a good set of pneumatic large diameter tires when you want to move to a different location and drive a little faster then it is never really an issue not to lift it up. here in SD there are no inclines so the side hilling is not an issue.
   / 60" vs 72" finish deck #8
I have been looking for a 5ft finishing mower for my 3005, found a Buhler for $1650. Very well built machine. My John Deere dealer has Bush Hog for $1800. Finishing mowers are OVERPRICED!!!!! I paid $1900 for my 296 Bushog and I know it will last a lot longer than a finishing mower.:mad:
   / 60" vs 72" finish deck #9
Bush Hog makes good stuff. Well worth the price.
   / 60" vs 72" finish deck #10
Thanks!
jnelson
The 28 hp will do fine with a 72" deck unless the grass it over a foot tall and thick. You will notice a little lightness in the front end when going up hills that you do not have with the 60" deck. My dealer turns out Kubota L2800's with 72" deck all the time without problems. So I feel your tractor will be fine with it.
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
1605 (A57192)
1605 (A57192)
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
KOMATSU D155AX-8 CRAWLER DOZER (A60429)
KOMATSU D155AX-8...
