Sticky on Water in Hydraulic Fluid?
   / Sticky on Water in Hydraulic Fluid? #1
Belchos
Redding, CA
1982 M4000
I have found a huge amount of water in my hydraulic fluid. I drained it and wiped out the reservoir tank, and will purchase and go through a couple filters and a lot of fluid today to try to purge. Looking for more help. Could not find a sticky or FAQ on this although I suspect it has come up often. Panicked. :eek:
   / Sticky on Water in Hydraulic Fluid? #2
Just do like you have mentioned,and run the cylinders through many cycles.
You need to find the source of the water leak. If left outside, at least throw a tarp/plastic over the tractor.
   / Sticky on Water in Hydraulic Fluid? #3
Welcome to TBN:D
I think you got it figured out...You need to flush the system AND find the source. You can use some cheap fluid till you get it flushed...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
1275 (A50490)
1275 (A50490)
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
