Oil & Fuel Low sulfur diesel ?
   / Low sulfur diesel ? #1
benelli
Member
Louisiana
Today I heard someone say you were not suppose to use low sulfur diesel in new model Kubota's. I explained that was incorrect. Has anyone else heard this as well?
   / Low sulfur diesel ? #2
It is mandatory in North America. That's what the owner's manual says.
   / Low sulfur diesel ? #3
Benelli,
The only proviso is with the engine oil used.
If you are using low sulfur fuel, use API rated CF-4 or CG-4 engine oil.
If you use high sulfur fuel and these oils, cut the drain interval in half (100 hours)
I can't imagine anywhere in the US that does not use low sulfur fuel - maybe in developing countries they use high sulfur fuel so that is why the manual specifies something different.
I think the guy was actually refering to diesel made a few years ago vs today's lower sulfur content to meet stricter emissons.
   / Low sulfur diesel ? #5
Except the OP said "newer model Kubotas".
ULSD is fine, only issues are with injector lubrication and you can easily add a little fuel conditioner to improve that.
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
1986 East Tri Axle Semi Dump Trailer (TITLE DELAY) (A50774)
1986 East Tri Axle...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
3 New 14in Premium Diamond Blades (A50322)
3 New 14in Premium...
Tires (A50322)
Tires (A50322)
