fuel line repair or replace??Yanmar 1500
   / fuel line repair or replace??Yanmar 1500 #1
cliff880
Both fuel lines that originate at the fuel pump and terminate at the injectors have worn and are leaking where the lines bend around the front of the engine block.I removed the lines and tried wrapping them with copper wire impregnated with JB Weld thinking that since they were small holes then this would work,it didn't Any ideas??
Cliff880
   / fuel line repair or replace??Yanmar 1500 #2
Replace them . Check some dealers on the yanmar section. They may have some parts tractors or a line set that will work
   / fuel line repair or replace??Yanmar 1500 #3
This is about the only repair that I have had to do that wasnt self inflicted, I used auto parts store fuel line and gave it a little twist before clamping
   / fuel line repair or replace??Yanmar 1500 #4
Save yourself the trouble later. Replace them.
   / fuel line repair or replace??Yanmar 1500 #5
If the fuel line stopped your leaks, let it ride till you have another problem. No since wasting money.....
   / fuel line repair or replace??Yanmar 1500 #6
Cliff880
Might have fixed a suction line.. but since those are multi-thousand psi lines.. I wouldn't have even trried that.
braze them.. run some extra brass around the areas with the most wear.
I have used brazed hyd lines with no problem..
soundguy
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
Engel 20' Boat (A50121)
Engel 20' Boat...
