BX 2350 service
   / BX 2350 service #1
charliepff
Harpers Ferry, WV
2516 Mahindra w/backhoe
I had a few questions about the 100 hour service on the 2350. First, due you need to drain the hydraulic fluid to clean the screen? Next, what did everyone due to service there units? Did you all follow the book or did you exceed what the book said to do. Thank's for the help and suggestions.
   / BX 2350 service #2
I pretty much follow the book. As I recall, mine called for a 50 hour service, and then a 100 hour. I believe the 50 hour service called out changing the hydraulic fluid and filter, plus the oil and filter. I did't clean out the HST screen at that time, as I recall that is called out at the 500 hour service. Knowing what I know now, I would have cleaned it. I think it would be hard to do with out losing alot of fluid.
Was the hydraulic fluid changed at 50 hours? If not I would do it now and clean the screen while you are at it. I'm not sure how cold it gets in your location, but if it gets cold, I would use Super UDT fluid, which lets the hydraulics work a little better in the cold. I will probably stick with Kubota fluids until I'm out of warranty. Check the air filter also. If you mow alot, they get dirty quick. It's also nice to have a couple of fuel filters laying aorund also. One of mine started to plug up at around 100 hours this last winter.
Kubota sells a kit that has alot of this stuff in it. Fillters and some of the fluids all boxed up. It doesn't have enough of the fluids you will need, but it comes with a cool hat.
   / BX 2350 service
I actually bought everything except for enough hydraulic fluid. I am going to change everything. I am behind with the service. Everything has been cleaned and greased frequently but I did not do the 50 hour service. Thank you for the suggestions. I usually have to blow out the air filter every time I mow.
   / BX 2350 service #4
On my Bx23 .
I changed the engine oil and the tranny fliud at the 50 hour service.
The next oil change was at 100 hours and every 100 hours there after.
The next tranny change was at 300 hours then every 300 hours there after.
I did it by the book.
John Deere (A50322)
John Deere (A50322)
Quick Attach Pallet Forks (A47384)
Quick Attach...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2006 Cadillac Escalade (A50324)
2006 Cadillac...
