12v cordless drill to run off truck 12v
   / 12v cordless drill to run off truck 12v #1
WantedWolf
Gold Member
South Alberta
ditch witch 6510
I didnt want to hijack kossetx's drill thread, but has anyone used an old 12volt cordless drill and converted it to run "corded" from a vehicals 12v power?
I havent seen a new 12v drill in years so the old drills should be a dime a dozen with a box of dead batterys.
   / 12v cordless drill to run off truck 12v #2
That should work no problem if you don't mind dragging around a very heavy battery. It would run a long time on a vehicle battery.
   / 12v cordless drill to run off truck 12v #3
Just get a cig lamp plug and adapter and 20' of zip cord..run it from the ca.. or from open hood with bat clips.. or from a carry-around motorcycle battery..etc.
soundguy
   / 12v cordless drill to run off truck 12v #4
I have an old 12 volt drill that I did as someone else suggested with -- soldered a cigarette lighter plug to and hooked it up:D -- works fine
   / 12v cordless drill to run off truck 12v #5
I did that with my old Crafstman after I couldent get batteries for it.
I took the battery pack apart holes some heavy lamp cord to were the batteries were and drilled a hole for wire to come out.
I'v only used it 2 or 3 times that way but it dose work.
btw I did fuse it at about 10 amps in one leg of the wire.
there is a youtube hack video on it but the drill was delta
tom
   / 12v cordless drill to run off truck 12v #6
There's also a guy on e-bay who sells individual batts and instructions to rebuild your bad batt pack. You'll have to do a search though, bec I can't remember his name.
Id only use it on vehical, I never like the cig plugs but that might be the best option. I dont even own a single cordless tool. I used many at work and they all died at the worst time, and bats are ussually to expensive to have more than 2.
If I come across a 12v drill I might do this. I suppose a 14v would work too?
   / 12v cordless drill to run off truck 12v #8
My 12V driill is still operational but old enough that the batteries are no longer available. I took the exhausted battery pack to my local Battery Plus store and they rebuilt the pack. Picked it up the next day and it's as good (or better) than new - can't even tell how they opened it to put in new cells. I also have a 18V drill & circular saw that I use for heavier work but that old drill is convenient for small quick jobs.
   / 12v cordless drill to run off truck 12v #9
I work with a guy who uses a 12volt Dewalt at work. He likes the 12volts because if the battery ever dies he can hook up a set of jumper leads to the cigarette lighter and charge the battery in transit. 15 or 20 minutes later he is back up and running.
Tom
   / 12v cordless drill to run off truck 12v #10
Hmm. I have a couple old 6v and 7v drills with bad batteries.. hmm.. I have 6v tractors.. ;)
I think I need to revive those old drills!
soundguy
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
JCT 84" Rock Grapple (A50121)
JCT 84" Rock...
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
1985 Chevy C8500 Altec D800 Digger Derrick Truck (A50323)
1985 Chevy C8500...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
