Found a 7710- need some parts prices
   / Found a 7710- need some parts prices #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I found a local Ford 7710 II 4wd Cab tractor. The tractor has 2250 hours. Hours appear to be orig. as the tach works and the tractor is clean. Heres the catch. It is equipped with a side boom mower that was used on the railroad. Present owner has agreed to discount price and remove the side boom. Here is what the tractor will need:
1) 4 new tires ( I guess the rocks on the rr tracks ate them up)
2) 3 pt arms etc (PTO has never been used)
3) Lift levers (In the cab)
4) Battery box
5) Steps
What will all this cost me? I need to know so I can make an educated offer on the tractor. thanks
   / Found a 7710- need some parts prices #2
Figure $7000 for all new parts and tires. It could easily be more than that. 3PT linkage and battery box/step supports are stupid money to buy. So much for a cheap tractor.
   / Found a 7710- need some parts prices #3
Are you saying it has no 3-pt system at all, no rockshaft, nothing?
What hydraulic pump was being used to run the boom mower, an original engine mounted pump? Is this the same pump that will be used to operate the 3-pt hydraulics or do you need another pump?
This sounds to be not only parts expensive but labor intensive. Will you have to remove the cab to complete the changeover, I would think maybe yes?
Are the tires/wheels the sizes you need for your application?
I think the only way this could work dollar wise would be with used parts from a salvage tractor.
   / Found a 7710- need some parts prices #4
As Rick said, the tires are going to be very expensive even for cheap tires. As for the rest of the parts go to www.messicks.com and type in the model and you can search for the parts you need and see the prices for them. I think mine cost $1700 for just the rear tires and they were on the cheap side. Figure in the tubes, possible rim work and mounting and you have an expensive tire replacement.
   / Found a 7710- need some parts prices #5
I think the best way for it to work is to buy a complete donor tractor and salvage what is left. Even used parts are going to add up in a big way. I'd pass altogether. Some of the most abused, most poorly maintained equipment I see is owned by municipalities and utilities.
   / Found a 7710- need some parts prices #6
call alexanders used tractor parts in winsboro texas----
4) Battery box
5) Steps
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
New/Unused 7ft Stainless Steel Workbench (A51573)
New/Unused 7ft...
