fence ideas
   / fence ideas #1
Beavis
Kansas
JD 4720
I have approximately 1000 ft. of frontage and would like to get some ideas for fencing. The fencing would not be used for livestock, but basically a boundry marker and something to prevent people from driving onto the property or around the gates. The neighbor has white vinyl fencing, which I'd like to stay away from. I have considered used telephone poles, old oilfield pipe, or even the treated post from Tractor Supply. Any photos that could give me ideas would be appreciated. Concerns: with oilfield pipe, what methods can be used to cap the top of them? With treated post from Tractor Supply, what is a real lifespan for them?
THANKS
   / fence ideas #3
Old power poles/telephone poles for posts every 50' or so with a few treated posts in between. Attach, let's say, 5 strands of high tensile wire. It's quick and easy and looks good.
   / fence ideas #4
Steel is high. Just bought 7 rolls of 12 1/2 ga 4 point barb wire. 75 bucks a roll. If I had done this 2 years ago the same wirs was 43 bucks. Steel T posts have come up 40-60 percent in the same time.
I'm all rural here so a 5 or 6 strand wire fence fits in ok. Wire come 2 pt or 4 pt or barbless.
Check with some of your area fence supply stores and look through their catalogs.
   / fence ideas #5
got cedars you could pull and strip branches off of to use for posts and stiles?
if you're not looking for something to keep critters in/out, it would work to let the world know not to traipse across, while helping you clear trash trees out of your pasture.
   / fence ideas
Unfortunately I don't have trees, but that is a good idea. I have thought about hiring a tree spade to move dozens of cedars from pastures; I think I can get the trees for free and the spade would probably be $20-$30 per tree.
I have also considered the single strand of 1/2 wire/cable between wooden post. Keeping it shorter; maybe 2' poles.
thanks
   / fence ideas #7
thanks
If you do use the wire, BE SURE you have it clearly marked so its easily seen in the wintertime against the white snow. Quite often, you might get a snowmobilier who didn't know where the boundry lines are and they attempted to cross the wire fence and get hurt. I read too many articles in the newspaper with people getting hurt from fence that wasn't there before. A line of trees is your best bet. My father has done the same thing, he mades sure whatever is wild growing has a buffer of wild growth gowing of 5-10 feet so its easily known where the boundry is. Perhaps you could bush hog a clearing of 2 bush hog width up and down the "fenceline" ? This is much more safter and more effective I think.
   / fence ideas #8
which part of Kansas are you in?
I may be able to find you a supply of cedar poles if you're willing to haul the brush as well - friend of mine is trying to expand the horse pasture.
   / fence ideas #9
Cheap fence to keep vehicles from freely driving in?
3 strand barb wire on t-post.. with wood corner posts and braces, and H style wood braces every 200'
cheap.. easy.. and you can put it in in a day by yourself.. just get the neat axe-handle style wire stretcher and a box of u-staples. get the wire caddy unroller and fence tool ( hammer/plier combo ) that many stores sell.. it's about 15$ for the unroller and fence tool.. and is invaluable..
soundguy
   / fence ideas #10
Do you want it to be attractive or just a barrier to keep people off your land? Wood will rot, but with a crown around the base of the post, you can get 20 years out of them. Oil field pipe is always a gamble. The pipe is always going to have imperfections inside of it that you cannot see. When you cut it or try to weld it, you will find that it's usually pretty thin and mostly worthless. Like Soundguy said, T posts and wire will be the cheapest way to go.
I have white vinyl at my entrance. I like it. But you said that you don't. There is also green, dark brown and black vinyl fencing that comes in a variety of styles.
I have a job coming up where I'm putting in brick columns every 16ft, with lights on top of them and a 6 foot wood privacy fence between the columns. It's very expensive, but the end results will be what the client wants.
How much do you want to spend? Will you do the work yourself? Can you weld, drill post holes or work with wood? Do you have a wife who has an opinion on what she wants the front of your place to look like?
Eddie
CUSHMAN SHUTTLE GOLF CART (A51406)
CUSHMAN SHUTTLE...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
198367 (A51243)
198367 (A51243)
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
