PTO--does on/off hurt engine
   / PTO--does on/off hurt engine #1
AppleMan
Member
Northern IL/Southcentral WI
JD 2305, JD 850, 1951 Farmall
Does shutting the pto on and off hurt the tractor's engine? I have to shut it off on about half of my turns at my orchard (ground is severely uneven in these spots) and didn't know if it would hurt the engine. In three hours of spraying I probably turn it on and off about 20 times.
   / PTO--does on/off hurt engine #2
I can't imagine how it could. Perhaps there are internal clutches that are getting worn or something (I would think this would be tractor dependent), but that would be about it. If you are only shutting down the PTO when turning around, why not leave it engaged and save the worry?
   / PTO--does on/off hurt engine #3
There would be more risk of damage letting it on from the vibration in the turn
The only thing you could hurt turning it on and off would be the PTO clutch and I wouldn't worry about that
   / PTO--does on/off hurt engine #4
Can you tell me what is meant by vibration in the turn?
   / PTO--does on/off hurt engine #5
Sorry, I guess I assumed the OP was talking about a rear PTO shaft in which in a sharp turn the U-joints produces a vibration
   / PTO--does on/off hurt engine #6
I think I'd save my pto clutches and invest in a CV style rear pto shaft!
soundguy
   / PTO--does on/off hurt engine #7
If you were running a rotary cutter or finish mower, I'd say you should not cycle the PTO ON/OFF. However, if you are running a PTO pump for a sprayer, it probably does not have anymore starting torque than a posthole digger. That would probably not put a lot of stress on the PTO clutch or the tractor's engine. So my answer is that if there is little torque required, go ahead. If there is a high torque requirement, then raising the 3PH in the turns might be the best option.
Thanks much. It is a trailer mounted (not 3pt hitch mounted) in which the pto powers the pump for the sprayer so I'll keep shutting it off on the sketchy turns.
   / PTO--does on/off hurt engine #9
Just checking, but are you using your Clutch to dis-engage (and engage) your PTO on and off? You need to with Transmission Driven PTO (not with Independent PTO).
Not using your clutch is the only thing I can think of that would hurt your engine by jamming it on or off. Don't mean to talk down to you, just checking.
   / PTO--does on/off hurt engine #11
Any chance of mounting the pump to the pto stucb on the tractor and 'hoseing' it back to the trailer? in effect.. get rid of the pto shaft and u-joints?
soundguy
   / PTO--does on/off hurt engine #12
With my 2210 the manual states that the engine should be throttled back when the pto switch is turned on or off. I always do. It really isn't a big deal to do it either I just have to remember. Occasionally I forget when turning it off but really isn't going to be when parts get broken.
   / PTO--does on/off hurt engine #13
If you hear the engine lug down when you engage the PTO, I would imagine that there is some excess wear. If there is not enough resistance to to strain the engine when it is turned on, I wouldn't worry too much.
I would worry more about a rotary cutter where you are spinning up a significan mass than with a spray pump.
   / PTO--does on/off hurt engine #15
There's no clutch on my model. It's a hydrostatic transmission.
Ok, just saw specs for your model that has Independent PTO. Shouldn't hurt the engine turning PTO off and on.
Fyi - Some tractors with HST use a clutch to change between Low, Mid-range and High Gears and at the same time it also has a dual function of engaging/disengaging the PTO.
   / PTO--does on/off hurt engine #16
Even if it had a clutch.. I wouldn't have viewed it as 'hurting the engine'.. rather as wearing the clutch material .
soundguy
   / PTO--does on/off hurt engine #17
Don't you still have a PTO clutch then?
I don't know if it is related, I have a Kubota deisel ZTR mower that is hydrostatic. They recommend putting the engine at idle before engaging the PTO.
   / PTO--does on/off hurt engine #18
I use a Rears airblast sprayer, a trailer type also. It has an electrically activated fan clutch that lugs the engine when engaging. The manual says to engage at low rpm.
I should have clarified. I do rev down before I shut it off. Thanks for the heads up that your sprayer manual says the same thing. I just wasn't sure because it doesn't address multiple shutdowns.
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
Kubota BX25D (A53317)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Nissan Rouge SUV (A59231)
2013 Nissan Rouge...
Sterling AT (A56438)
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
