Do you want it to be attractive or just a barrier to keep people off your land? Wood will rot, but with a crown around the base of the post, you can get 20 years out of them. Oil field pipe is always a gamble. The pipe is always going to have imperfections inside of it that you cannot see. When you cut it or try to weld it, you will find that it's usually pretty thin and mostly worthless. Like Soundguy said, T posts and wire will be the cheapest way to go.
I have white vinyl at my entrance. I like it. But you said that you don't. There is also green, dark brown and black vinyl fencing that comes in a variety of styles.
I have a job coming up where I'm putting in brick columns every 16ft, with lights on top of them and a 6 foot wood privacy fence between the columns. It's very expensive, but the end results will be what the client wants.
How much do you want to spend? Will you do the work yourself? Can you weld, drill post holes or work with wood? Do you have a wife who has an opinion on what she wants the front of your place to look like?
Eddie
Eddie,
First, I've always valued your objective input on this board and greatly appreciate the photos that you have shared.
An attractive appearance is a must and I'd like for it to blend in with a 20' gated entry(gated entry hasn't been designed yet). I can do most of the work myself to save cost. I guess maybe I posted too early, with too little information. What would be a fair price for a brown vinyl fencing ?
THANKS
