Finish Mower Size
   / Finish Mower Size #1
damartin
Member
Pennsylvania
John Deere 790
Hi I posted this question on the buying/pricing forum along with my introduction but thought that this may the right place to post it.
Is a John Deere 790 big enough to power a 6' finish mower or should I get a
5' finish mower in order to be sure that there is enough power to operate it properly.
   / Finish Mower Size #2
If you use a finish mower as a finish mower, and not as a brush cutter you will be fine with a 6 foot.
If you get into heavy taller grass just pick a lower gear until you get into the stuff you should be using a finish mower for... KennyV.
   / Finish Mower Size #3
Remember A finish mower is just a lawn mower nothing else. The blades are pulled by a belt not direct drive like a rough cutter. Cutting high grass is hard on the belts. you should be fine with a 6'.
   / Finish Mower Size #4
You've got the power, but I'm not sure you've got the hydraulics. The 790 is rear lift is only rated to 815 pounds. My finish mower for example, weighs 860#. The other thing is front weight. If you've got a loader, no problem. But if not, you don't even have to get near the rear lift max to make the front end too light when carrying. A light duty six footer may be ok, but could be a little delicate. You might be better off with a standard duty five footer.
//greg//
   / Finish Mower Size
Thanks for the info, I do have a loader on the front.
I have been looking at a used 6' Land Pride that weighs a little over 600 lbs. I'll probably buy it if it's still for sale when I find enough time to pick it up.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
CATERPILLAR 819 PADFOOT LANDFILL COMPACTOR (A51242)
CATERPILLAR 819...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Online Buyers Premium (A47384)
Online Buyers...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
1262 (A50490)
1262 (A50490)
