Help with Stihl/Oregon Sharpening guide
   / Help with Stihl/Oregon Sharpening guide #11
Yeah,I bought one several years ago,think I looked at it,read the directions,and,figured that was wasted money,never did use it.
Maybe if they worked as advertised and you had time to see just how factory like you could get chain,maybe.
I can get it almost as good as new,but not quit there,by hand in 15 min or maybe a little more,so.
Main thing I've learned is to use new files.
   / Help with Stihl/Oregon Sharpening guide #12
As the chain wears, should i keep the "tooth stop" (#1 in your pic) in the same place and adjust the acorn nut? Or leave the acorn nut and adjust the tooth stop?
Ill throw up a couple pics of my sharpening adventure:p
It looks like you got it down.
The sharpeners that I am familiar with the "tooth stop" isn't adjustable. The only way to ajust how far back you cut the tooth is with the acorn nut (#3 in the pic). If you sharpen now til your center bar hits the acorn nut, next time you sharpen, you won't remove any material unless you tighten the acorn nut a little.
   / Help with Stihl/Oregon Sharpening guide #13
o i almost forgot to ask....
What model is that little husky?? Dad has a 136 with a 12 or 14" bar but yours looks a little bigger. I'll guess maybe a 140 with a 14 or 16" bar?????
Its a Husky 51. 16" Oregon bar. Wish it was a little bigger, but its been a pretty good saw.
   / Help with Stihl/Oregon Sharpening guide #15
I finally got mine working properly. It was just a pain to set up. Once I taught myself how to sharpen without the fancy guide, I could sharpen the entire chain in the time it took me to set up the fancy guide.
I've got an Oregon 511 clone electric sharpener. It works, and works well. But, it still takes longer to set up and sharpen than what I can do by hand. And, doing it by hand I think gets it a bit sharper.
   / Help with Stihl/Oregon Sharpening guide #16
May be some help or not?? Put a larger C clamp on the saw blade and then clamp the C clamp in a vise. That will give nice solid point to work from. The chain can still be moved by hand and you can face the saw or approach it from either side which may make your work station a little more user friendly. :D
If you have a proper vise forget the above senior ramblings.:D
   / Help with Stihl/Oregon Sharpening guide #17
You don't even need a c-clamp. Just clamp the middle of the bar in the vice so the underside of clears the jaws and it works perfictally.
Another note: Always sharpen from inside to outside. Exactally the opposite of sharpening a knife. You chain will be sharper and the files will last longer.
A lot of people like the bench top electric grinders but not me. The time it takes you to take a chain off and put it back on, I can be done sharpening. From start to finish, it takes me about 4-5 min to do a 24" bar on the 7900.
The key is not to wait until the saw is dull and won't cut anything. Keep it maintained and you only have to take 2-3 file strokes off each cutter.
Thats not a bad idea Egon. With my small bar, i cant clamp it into my vice and use my new sharpener (jaws on vice too big). Ill give the clamp trick a try next sharpening.
   / Help with Stihl/Oregon Sharpening guide #19
I was using one of the little Oregon red diecast and plastic guides and found I could not get consistent results. The chain always popped up out of the clamp over the rivets or the entire fixture would rise up out of position. If I had the chain clamp tight enough over the rivets, the chain could not be easily advanced to the next tooth. I used sharp files and counted the strokes but somehow never got consistent results.
Yesterday I received an Oregon grinder from Northern Tool. It took me about 20 minutes to set it up and 30 minutes later I'd sharpened 3-4 chains with no hassle. I quickly found out how inconsistent my filing had been. (Even with same # of strokes, the file pressure resulted in variation.) They are now consistent and definitely better than my attempts with the Oregon jig. I haven't cut anything yet but am sure, after reading the pre-purchase reviews, that they will be sharper, more consistent, and take less time than before.
I have three saws - 12", 16", and 18" - all with spare chains so I bought a little 5 draw plastic cabinet from housewares at Walmart. Three draws hold sharp clean chains sorted by size, one draw has the extra grinding wheels, and the top drawer has tools. I'll be better off and spend less time.
   / Help with Stihl/Oregon Sharpening guide #20
It all depends on the type of vise you available!:D:D:D And the location of the vice!:D:D:D
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
