Mulch Blades
   / Mulch Blades #1
Scrounger
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I have a 60" deck on my BX2230 and its time for new blades. I dont have a mulch kit but was wondering if new Kubota mulching blades would be a better option than the standard blades. I gave up on Gator Blades since they dont have an exact fit for my deck.
Recommendations?
   / Mulch Blades #2
I was thinking that gator did finally make a set that would fit the 60" MMM search last summer for nbrs. But even making the bushing isn't that hard.
   / Mulch Blades #3
Hi Matt. Long time no see. I have mulch blades on my 60" deck on the BX2200 and I love them. The turf needs to be dry and you have to take off just a little from the top for them to work with no thatch. I get windrowing and thatch on my first cut of the season because I have to wait for the ground to dry from the long winter rains. Once I have it short, it's great. No bagging, no fertilizing (nutrients go back into soil). I do have the advantage of no summer rain, coupled with irrigating on Mon. & Tue., then cutting on Sun. after turf dries on top. I sharpen with vice and angle grinder (freehand) once each spring. Good luck!
   / Mulch Blades #4
I put the mulch kit on my BX2350. It was expensive, it seems like around $3000. It came with a large baffle kit, and the blades. The baffles really change the underside of the deck and are fairly long. It wasn't easy to put on but not to bad either. I have been happy with the way it cuts also.
   / Mulch Blades #5
Good lord man! I hope you got a mower deck with that baffle kit for that price. Or else you meant $300, which would be more in line with Kubota pricing strategies.
   / Mulch Blades #6
I built a mulch guard from a bagger boot. After installing a 16 gauge sheet metal insert, I was ready to mow. This way I can easily switch from bagging to mulching without getting under the deck. I really like the look of bagging best, and with the powerflow bagger it doesn't clog. However, if the grass only grew 1-2 inches mulching works well and returns nutrients to the soil. I use standard Kubota blades for mulching and bagging and they work great.
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2025 LandHero 45mm x 330mm Universal Bucket Pins (A49462)
2025 LandHero 45mm...
