Tooth bar suggestions?
   / Tooth bar suggestions? #1
Dale1995
Caribou,Maine
John Deere 2320
I have a 200cx loader on my JD 2320. I have some soil removal this summer and am thinking that a tooth bar might help to loosen up the hard packed soil. Will a tooth bar make a big difference, or am I just wasting my money? What type / style tooth bar do you recommend? Who has the best one for the best price. I hate to reinvent the wheel, since so many of you out there are seasoned professionals. Any help would be appreciated:confused:
   / Tooth bar suggestions? #2
A tooth bar will help a bit. It's different with a toothbar on a CUT, in my opinion. Perhaps I was biting off more than I could chew, but it seemed like with the tooth bar on the bucket it just dug in so much more aggressively that I didn't have enough powerand weight to really dig in.
I actually have not even used it in a couple of years now, mainly because I have to drag a lot of smooth surfaces and use the front edge of the bucket to do it.
I got mine from this place:
Markham Welding - Tooth Bar
Chris
   / Tooth bar suggestions? #3
What Torquin said.
Well worth the investment.
   / Tooth bar suggestions? #4
What Torquin said.
I agree!
Without a bar a 4 inch stone will deflect the bucket resulting in slim pickings.
With a tooth bar you get full buckets every time.
My CUT is only 20 HP and it loads like a skid steer and I can move and place a 10 wheel truckload of mixed fill (like lots of stones in the load) in about an hour.
Also can actually excavate vergin stony soil just like a backhoe.
Best, handiest accessory purchase I've made to date.
Downside is that you'll have a hard time backblading to a smoothe finish, but there is a good excuse to get a backblade!
Note that tooth bars are easily remouvable, just 2 bolts.
   / Tooth bar suggestions? #5
This is a topic covered numerous times in numerous threads here on TBN.... try a search and check out the volume of info already available re toothbar usefulness.
Fundamentally I'd venture that 85% of toothbar owners swear by them. Occasionally a tractor driver simply actually had almost no need for a toothbar. They not only are used to dig into material, but have about another 20 documented uses... a worthy investment.:D
   / Tooth bar suggestions? #6
Dale
Wow Caribou Maine. Spent a bit of time at Loring AFB back in the 70s. It was our support and R&R base when I was stationed in northern Canada back in the 70s.
I have an ATI toothbar on my 200cx and in the high clay soil I have it is worth its weight in, well maybe not gold but certainly close. In the summers here, the soil got so hard I could only scuff the top. Now with the toothbar, I can dig down and actually get something accomplished. My ATI is probably overkill, it is really for a skid steer and is much heavier duty then our small tractors will ever need. But definitely get a toothbar: it helps a lot.
   / Tooth bar suggestions? #7
i have a toothbar on my 430 loader, it makes a big differance we have had packed soil with rockes i can dig a few inches i bought mine from my jd dealer the teath on mine are replaceable and are steel forgings.
   / Tooth bar suggestions? #8
Really like the Markham tooth bar and want to order one. Will it work better to add 1 or 2 extra teeth to the standard tooth bar? They seem to space too far apart comparing to what I saw on a skid steer. What's your experience/opinion on adding more teeth to the bar? Thanks.
   / Tooth bar suggestions? #9
I just moved about 100 CY of dirt in my back yard. Moving large hills and filling in deep valleys. I could not have done it without the toothbar especially when I got into some hardpan. Opinions vary but I would have nothing but the flat bottom (W.R. Long) toothbar for any type of landscape work.
   / Tooth bar suggestions? #10
I "oops'ed" and got the W.R. Long toothbar but did not get the flatbottom one like I wanted; so be aware there is a difference.
I just got the middle buster, and would suggest it as a option for moving dirt. use it to break it up then bucket it over to the new area.
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
