Tooth bar suggestions?
   / Tooth bar suggestions? #11
Stumpfield
I have a 53 in bucket and ordered my toothbar with 7 teeth. It comes standard with 5. I think more teeth helps but since I have never used a stock one could not tell you for sure. My toothbar has a slot cut in it that the front edge of the bucket slides into. That helps stiffen the bucket when I move the occasional (really, really, really numerous):D rock I find at my place.
   / Tooth bar suggestions? #12
Really like the Markham tooth bar and want to order one. Will it work better to add 1 or 2 extra teeth to the standard tooth bar? They seem to space too far apart comparing to what I saw on a skid steer. What's your experience/opinion on adding more teeth to the bar? Thanks.
Depends on the power of your tractor. Remember, more teeth will spread out the pressure of the tractor's force. Fewer teeth will exert more force on whatever you are trying to do, all other factors being the same. Now, that said, if you only have 3 teeth, for instance, you might not be able to get as much done because the 3 teeth dig in and that's about the time your bucket edge hits the hard dirt, or whatever, and you find that your tooth bar is not, or is moderately, effective.
Hate to confuse you, but I'll say that I did not add more teeth to my bar when I ordered it. I figured these guys knew what worked, and since I did not have a special application where I knew better, I'd just leave it alone.
Chris
   / Tooth bar suggestions? #13
Chris
So, is more teeth better or worse? I got a 72 in bucket and the tractor has 33 hp. Thanks.
   / Tooth bar suggestions? #14
Just remember to drill the mounting holes to the front of the slot, that way if you ever need to you can loosen them and fold the toothbar back into the bucket and not have to remove it. BTW, love my Markham.
   / Tooth bar suggestions? #15
I ordered and installed the Markham tooth-bar on my L3130, and don't know how I ever got by without it ! I had Markham install an extra tooth on each end of the bar, spaced 8 inches inside the outermost tooth. Now, I can easily insert either end of the bar underneath small stumps, etc. and just rotate the bucket upwards, to "grub" the stump out of the ground. It hasn't been a problem with "back dragging", because I normally tilt the bucket up and use the rounded portion of the back of the bucket for that purpose. Also, if the tooth-bar becomes a hinderance to back-dragging, just loosen the mounting bolts and swing the bar upwards into the bucket (hope that makes sense).
   / Tooth bar suggestions? #16
I have an ATI on my Kubota L4240. I took the toothed bar off for the winter. I just started using it last week to move a dirt pile and level an area for seed. It worked great. The teeth dug in just enough during back dragging to get small roots and sticks and then left furrow of dirt that made for easy raking while removing the stone by hand. My previous tractors did not have a toothed bar. There is a clear advantage to having the teeth for digging.
Mike
   / Tooth bar suggestions? #17
In my use a toothbar was clearly better for digging than a standard cutting edge.
Again, it depends on the power and weight of your tractor. You can't expect to dig like a commercial industrial tractor or loader. But the answer is a toothbar will let you dig better than a standard cutting edge.
More teeth are not necessarily the answer. They need to act like rippers and bust up the hard soil before the bucket lip gets to the soil. Torquin explained that nicely. I did not get any extra teeth on my Markham toothbar. It works great just the way it is. In some cases the ground is so hard that I have to rip it with the scarifiers on my boxblade first. There are limitations to everything. Just need to use your head a little.
For backdragging I use the back of the bucket and not the bucket lip. I think it's safer on the hydraulic rods to do it that way anyway. My toothbar has never been off since I installed it 4 years ago.
   / Tooth bar suggestions? #18
I have a BX2350 with a 48" FEL. I ordered it with grab hooks welded to the upper corners of the bucket but I've yet to use them. Three months after I bought the BX last summer I ordered a Markham tooth bar with the standard five teeth. It is extraordinarily well built and it has been the best add-on investment I've made thus far. Every time I use the loader I'm thankful for the tooth bar. I had given thought to six or seven teeth. Melissa Markham suggested that too many teeth on a smaller bucket works against you. Six would have been okay but five does everything for me that I need doing.
Doug
BX2350, FEL w/Markham tooth bar, BushHog 48" tiller, Kodiak 5' landscape rake, used Loftness 48" 3ph snow thrower, plus other stuff.
   / Tooth bar suggestions? #20
I went outside and banged my head against the ground, It did really work and now I have a headache. People here give some bad advice!
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Cargo Mate Enclosed Gooseneck Trailer (A53117)
Cargo Mate...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
