Disposal/Use of Old Gas?
   / Disposal/Use of Old Gas? #11
I cut it 50/50 with old deisel & keep it in a sprayer for Wasps in the out buildings . Of Coarse You have to be carefull when Spraying, Wear goggles & NO smoking . I Wont spray it around the house either except in the critter holes . Also makes a Quick weed killer for outside areas . :D . Bob
   / Disposal/Use of Old Gas? #12
I'd mix in with fresh, or the fun way......ant beds and matches. Just poke a hole in the bed with a sharp stick first.
My wife says it's tough raising a 10 year old husband.
   / Disposal/Use of Old Gas? #13
I've mixed old gas with new and burned as well.
I just puleld an old 1954 naa out of my shed that has sat for 4-5 years and had about 2g of old gas in it.. I dumped in another couple gallons and some mmo and let her run.. no problems....
soundguy
   / Disposal/Use of Old Gas? #14
My Ortho Western Gardens Book, circa 1950, recommends old gasoline for spot weed treatment along walkways and drives...
Application is by pouring...
   / Disposal/Use of Old Gas? #15
If you don't mix and burn it in your mower, be sure to keep a gallon of it around for parts cleaning.
I re-use gas several times because the deposits filter down to the bottom. Then I use that old gas to clean off oily surfaces I need to work on. It's always good to have a little old fashioned degreaser like that for odd clean up jobs before working on the parts.
   / Disposal/Use of Old Gas? #16
you remind me of ..... my DAD!:eek:;)
   / Disposal/Use of Old Gas? #18
First and foremost, I will use it somehow- mixed for lawnmowers -weedkiller, or in the truck, as many of the past posters have said.
But if you find yourself with some BAD gas and you live in a weed free state- I have a 5 gallon gas can I put my old motor oil in, to transport it to the authorized disposal places (in my case, work) I just add it to it, or use it to help clean out the gas can. Anyway, recycling it with the used motor oil is OK in my state.
   / Disposal/Use of Old Gas? #19
used motor oil will likely be gas contaminated anway...
soundguy
   / Disposal/Use of Old Gas? #20
One thing not mentioned.. If it's very old and contaminated, you can donate it to a local business that has a waste oil burner..a little old gas in waste oil works fine. Everything is filtered before it gets to the furnace.
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
20" Sea Container (A47384)
20" Sea Container...
2002 Ferguson SP915RE Ride-On Pneumatic Asphalt Compactor (A52377)
2002 Ferguson...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2842 (A54757)
2842 (A54757)
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
