Flatheadyoungin
never use an oily glove on the shut off valve of you oxy tank.....can (key word here) combust without an ignition source...
there are 3 or 4 major welding supply shops in St Louis metro area. I visited most when trying to set up my new mig welder.
From my experience, the big shops that are going to be able to provide all those cool services, loner bottles, rebuilding gauges etc, arnt interested in dealing with the small hobby guy that comes in for a single refill once a year. They have way more to do than mess with such insignificant sales.
My advice, shop online, buy online. ITs going to be a fraction of the price for the exact same products. Your not going to miss out on any "services" that the local shop MIGHT provide if you bought the torch, and supplies there.
I always try & support my local dealers....but....for the frequency of use, it is just hard to swallow a minimum of $500 for a new import set & one tank, or $800 for a Victor set & one tank. I am thinking of a good used set of gauges, then buying a tank and whatever accesories I need from the dealer. One reason is that when I moved here I had a brand new welding tank I had bought in FL with my Millermatic 210. I went into this same dealer(here in TN) & was unable to get it filled on the spot(yes I was in the middle of an important welding job) because I couldn't prove ownership. Apparently crossing state lines with a welding tank falls under some Lindenburg kidnapping statute setting off all type of Homeland Security & Nato claxons. I ended up having to later contact my original dealer, have a letter sent stating that "yes, Mr M7 is the rightfull owner of said new welding tank...blahblahblah". Next I had to stencil my name and ph # all over the tank before bringing it in for a fill. Needless to say, I had to buy another tank before all this could take place so I could finish that job............wait...!......can I use that tank I already pruchased for this cutting set up, or am I going to get the "No Sir, this here tank is "special" for cutting"...?? Oooooh, I might be onto something here.......
RD
RD
I appreciate the info. I did consider a plasma, but reach might be a problem as the dozer is D.R.T. about 30' away from a 220 outlet.
