Ford 861 clutch
   / Ford 861 clutch #11
It definately has a 5 speed. My cousin from whom I bought it, was told it was an 861. But he kinda thought the 8 was the series and the 61 was the year. That's when I went in to search mode.
8 is engine size ( 172 ci gas or diesel ( lp? )
6 = 5spd trans with live pto
1 = year range.. 58-62
look on t he bellhousing aft of the starter.. the sn is stamped with the model Id.. etc.
soudnguy
   / Ford 861 clutch
soudnguy
That I believe is where identifying old ford tractors said to look but with the years of rust and dirt, it hasn't been possible yet. Thank you though.
   / Ford 861 clutch
Talking with the New Holland dealership within 12 miles of me price for a reman is $450.00, brand new $1500.00, labor $800.00 to $1000.00 plus possible cost to resurface flywheel. Close to the price of $1600.00 material and labor my cousin was quoted from another New Holland dealership about 35 miles from me. Being in a hurry (doesn't pay) I forgot to ask about warranty, material and labor. Of course when I mentioned that I heard reman might not be the way to go, the dealership said they hadn't any problems with this manufacturer.
   / Ford 861 clutch #14
There's nothing wrong with a reman clutch from a reputable supplier. Once again, the flywheel WILL NOT need resurfacing because it is not a friction surface for the clutch.
   / Ford 861 clutch
Thanks, If I have someone else install it, I'll be sure to tell them not to do the flywheel.
   / Ford 861 clutch #16
I just find it quite odd that someone at a NH dealership, presumably the service manager, is mentioning the possible expense of turning the flywheel of an 861 as part of a clutch job because it is completely unnecessary. Unless it is just an oversight; after all, most any dry clutch repalcement quote other than one on a double clutch Ford from 55-64 should mention the possibility.
   / Ford 861 clutch
When I spoke in person to the service manager, I asked him how much would it be to change a double clutch on a ford 861 diesel. I also wondered how long they would have the tractor. He told me between $800.00 and $1000.00 depending on how things went. More if the flywheel needed to be turned. He told me to figure a week to have the tractor because a day to take it apart to count the studs (??? I think it's what he mentioned) to get the right double clutch, two to three days to get the part ordered and in, and a day to put it back together. He didn't use a reference book like I've seen autoshops due to give a quote. So who knows???
   / Ford 861 clutch #18
count splines maybee?
soundguy
   / Ford 861 clutch #19
The price of that clutch pack is about right. Last year I was looking at a Ford 961 (the high clearance row crop version of the 861) that needed a new clutch. I found a reman unit on the web for about $550. Labor seems a tad high. I would have expected $600-700.
   / Ford 861 clutch #20
Hey. I found some old pictures of when I replaced my clutch in my Ford641 about 10 years ago. I did it with very few tools. The most difficult thing is ensuring that the clutch settings are proper such that you will not get chatter. For this you need a jig and then some lock tite. You can't adjust it once you put the tractor back together. It took me one weekend but I did other work that weekend. Also, don't over torque the clutch bolts - I broke one off and had to drill and retap it. Good luck. Here are a couple of photos but the quality is poor. It is pictures of pictures - ****.
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
