wHAT WOULD YOU DO?
   / wHAT WOULD YOU DO? #11
Does your tires leak now? or do they just have small weather cracks in them? slime is this stuff you buy that you put in your tires to stop leaks,its sold every where,if you just got a small leak in one,get some and follow directions,it works.
If you need new tires,order them someplace,take the wheels and old tires off,and go to a tire place and have them put them on for you,would probably be cheaper.
My tires on one lawnmower are about 15 years old and on another about 12 years old,original tires,all are cracked and full of slime.
Now sharpening the blades,you take deck off,you remove blades,you get you a small bench grinder,or use a hand grinder or you could even use a file,you sharpen them,[check into how to make sure they are balenced] and you put them back on same way they came off,maybe a 2 hour job. You should sharpen lawnmower blades at least once a year,guess you have never done this? no wonder they need sharpening,might have to buy new ones but bet I could get them sharp.
   / wHAT WOULD YOU DO? #12
I agree with someone above. If you can't do most of those items yourself, you ain't gonna like having an older tractor. While they may last longer they also seemingly need CONSTANT small fixes and repairs. If you can't do them, then the shop is gonna make a TON off of you.
+1.
Older stuff is fine but can quickly turn into major $ if you can't do the work yourself.
   / wHAT WOULD YOU DO? #13
You don't mention the price of the 1018, what are they asking?
I'd go with the 149. For $650 if its really in good condition with nothing needed to start it up and mow you'll have a great tractor for short money, thats in the right price range for a good 149, particularly with the plow. You can learn a bit from maintaining it, easy to do routine maintenance on that style tractor.
Didn't you buy the 1882 a week or so ago? Don't get me wrong, I'm all for having multiple tractors, but why are you looking for more so quickly after buying the first?
The 1018 is mine and my brother in law wanted to buy it from me for $800. It runs great but only has a 42" deck and it takes me around 2 plus hrs to mow my yard.
Yes, I bought the 1882 took the FEL off, attached the deck and mowed. It roughly took around an hour and a half. My thinking for having another tractor is twofold. The 1882 is 19 years old and I don't want to run it twice a week mowing. I thought of it as a utility tractor. Plus I'm going to plow up a garden with it and plow the driveway in winter. The 149 has a 48" deck and hydro lift and hydro trans. I think that it would be the perfect mowing tractor. Plus I'll pocket $200 from selling my smaller 1018.
BTW the 1882 mowed like a freakin tank! It is an awesome ride.
Here's another possible scenario: my neighbor down the street offered to buy my LT1018 for $300 and give me his CC109 which he uses semi-regularly (and looks pretty decent too). Problem is that the deck is a 42", yup same small one that I have on the 1018. Here's my question: is it possible that the 50" deck from the 1882 will fit on the 109?
   / wHAT WOULD YOU DO? #16
The 1x9 series is older than your 1882 by 10 or more years. No, the deck from the 1882 won't fit, and the 109 has 10 HP while the 149, from the same series of tractor, has 14 HP and will be better suited to spin a 50" deck, though I can't remember if 50" was offered for a 149, I think so.
I don't follow your comment about the 1882 being 19 years old so you don't want to run it twice a week. That is a great tractor, strong and capable, I'm assuming it has a 48" deck and will cut great. I do understand if you just want to leave the loader on it and use another tractor for mowing. But, if you want to decrease your mowing time you need enough power to spin a 50" or 54" deck while moving at decent speed, and the 1882 with 18 HP will probably mow faster than the 149.
I hope this helps, bottom line is you need a big deck with power to spin it, so I'd say 14 HP single is minimum on the older Cubs, 18 HP twin is minimum on the newer Cubs.
Thanks Dave for the insight. The 1882 has a 50" and it mowed great. My only fear is that I don't want to over work it with it being 19 years old. I original thought of it as a " utility tractor" and not necessarily a "lawn mower". Do you think that it could handle the twice weekly mowings? I just thought that it was "too" big a tractor to be a twice a week mower.
Along the lines of horse power, to spin a 48"-50" deck, do you think that I would need at least 16 to 18 h.p.? A 782 or 1600 series tractor would fit that.
   / wHAT WOULD YOU DO? #18
Here's my opinion on mowing with the 1882 - if you use it to mow twice a week, it will probably last longer than if you just use it once every few weeks! The twice a week mowing adds up to 3 hours per week, and in Buffalo you might mow 16-20 weeks, so maybe 60 hours max per year. You should be able to put 1,500 plus hours on the tractor with good routine maintenance, so that's a lot of years (I don't know how many hours are on it now).
I answered the HP question in my last post, hopefully I made sense.
I think you mix up the Cub series a bit, which tractors are older or newer. Take a look at one of the Cub reference sites to get an idea of what was built when.
Don't get me wrong, I love the idea of you having several tractors for different tasks. I'm not surprised the 1882 mows so well, the Super Garden Tractors, which the 1882 is, are very solid and strong tractors.
Maybe I have to just rethink things a little. The 149 that I was looking at is form circa 1970-75 I think. After reading all the opinions regarding it on this thread and others it just seemed like a nice strong tractor that would fit the bill nicely as far as mowing my 2.0 acres. To be honest with you the 1882 did a great job mowing and was fun to drive. I am just afraid that I don't want to beat on it too much as far as snow plowing and mowing go. I understand your point regarding mowing and it made sense. Now as far as plowing goes, I might only use it about 6 -10 times a winter. I guess that that wouldn't be beating on it now would it?
Maybe I am just trying to rationalize a way to "collect" a great looking older tractor( 149) and have a use for it!
BTW the 1882 only has 335 hours on it, that might not be accurate but I'm about 75% sure it is.
Thanks again for your thoughts.
   / wHAT WOULD YOU DO? #20
Or will the 109 cut at a higher forward speed?
My GT2554 goes pretty fast by today's standards(actually about the right speed) but I could go MUCH faster yet with my old 1872. I'm working on a Murray right now an it is down right a slug in it's forward speed.
(4) KUBOTA TRACTOR RIMS (A57192)
(4) KUBOTA TRACTOR...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
2017 Chevrolet Express 2500 Cargo Van (A55852)
2017 Chevrolet...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
John Deere 3025E (A53317)
John Deere 3025E...
