Pulling up posts w/ 2620 FEL
   / Pulling up posts w/ 2620 FEL #1
FN in MT
Craig, Montana
Gentlemen,
I've NEVER pulled up posts with a FEL and have about forty to do. They are all old wood posts, 12-14" diam that were sunk 2 1/2-3 feet. Pulled a few tonight but being new to this I was pretty cautious.
I raised the bucket and at 3-4 foot up the post I slowly pushed them back and forth until they got loose. Then dallied a chain around the middle and attached the other end to the edge of the bucket. Took several ups and downs before I could pull them out. Then again...they are sunk in there DEEP.
Should I have the bucket ABOVE the post with the chain centered on the bucket? I tried with the chain at both the bottom and midpoint and they were tough to get UP. Had the chain on the side of the bucket on my welded on eye hook.
This is all pretty new to me so I was being very cautious. Oh Yeah...the new 2620 finally showed up. I'll post some pics tommorow.
FN in MT
   / Pulling up posts w/ 2620 FEL #2
i have pulled a bunch of posts like that. wiggled em gently first, and then hooked chain low on post,with bucket and then curled bucket, seemed to have more lift and power that way. try and hook it to the middle of bucket, too much strain at corners. helps to curl bucket to dump position and then lift, you can get close to post that way. hope this helps
   / Pulling up posts w/ 2620 FEL #3
Like botakix said, don't use a corner. You can bend things that way. Also, when backing up in four wheel drive, be careful! The torque of the tractor will easily lift its rear off the ground, even with a counter weight. I only have a little BX2350, so it happens to me more often. When I did it off the corner (one time, I might add!), it almost rolled.
I just learned that wiggling while lifting makes a hug difference. Just this month, I was using my bucket truck to pull a post that was lightly cemented into the ground. We kept snapping a nylon rope, even with much of the dirt shoveled away. A guy showed up late, walked over, and while I was pulling the post (strapped at the base), he gently wiggled it with his hands, and it popped right up.
Again, wiggling while lifting will get you in the most trouble, as the tires will lever you right up in the air. It's best if you are pulling forward and lifting - just don't poke holes in the front of your tractor.
Jesse
   / Pulling up posts w/ 2620 FEL #4
I route the chain over the center of the bucket, keep it real low to the ground, curl bucket up to pull out post....barely have to raise bucket...just the curl of the bucket does the trick. Also - I have used 3 point to lift out posts.
Where are the OSHA safety police when you need them?
Back at their million dollar building writing more and more Regulations to keep themselves employed for many years to come.
Though I'm sure there are a few Field staff out there putting some poor guy out of business with time wasting inspections and high dollar fines for minute violations.
BTW...... ROLLING back the bucket works FAR, FAR better than how I THOUGHT I should pull a post. Read the FEL manual last night and was amazed at the difference in power on a roll vs simply lifting the bucket.
Live and learn.
FN in MT
   / Pulling up posts w/ 2620 FEL #8
You want the chain in the center of the bucket, but looped behind the bucket so its pulling up from the back. This gives the lift cylinders the best mechanical advantage. Use a long chain. In fact, the best pulling would be to keep the chain as close to your radiator as possible. For example, I just bought an 18" ID cement and steel sewer pipe. It weights about 1600 lbs. With the chain far forward (using the bucket edge to hook the chain, the loader could not lift it. With the longer chain slung behind the bucket, I snatched it right off the trailer. Don't forget to add some air pressure to your front tires. They take the brunt of the lift force. I presume you have some/enough weight on the rear. A heavy 3pt implement will help. Put rocks and stones on it to add to the effect. (water trough even works).
   / Pulling up posts w/ 2620 FEL #10
Turn around & use the 3pt hitch, it is stronger & safer. Run a chain low around the post & hook it to the lift arms. Lift & if needed, give it a shake forward & back. You might need to lower the arms & get a second grip to finish the job.
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
