Diesel Generator
   / Diesel Generator #11
OP, you will be a lot happier with a genny that is running 1800 RPM vs. one at 3600. Difference in noise level and life are two issues that immediately come to mind, and I also believe 2x RPM has to be less fuel efficient (sorry Soundguy, opinion on fuel efficiency is mine).
using your logic, a brush hog that requires 1000 rpm pto uses more fuel than one using 540.. unfortunately.. all things being equal.. it don't work out that way.
fuel used is a function ultimately of electrical load.
Would you believe my 70hp tractor and 10' mower use the same gallons of fuel as my 95hp tractor and 15' mower, when mowing a 10 ac parcel.. 10' takes longer.. but net effect is 10ac of mowing is 5g of diesel... It's a fuel vs work thing...
I agree a 3600rpm unit will likely emit more noise than an 1800 rpm unit.. however if we are talking pto gensets.. the input will still be looking at 540rpm.. and the gearbox will be the part making the noise.. not sure if you will hear that over the engine.. guess it depends on the tractor and exhaust system..
soundguy
   / Diesel Generator #13
I went through the same dilemma, I knew I wanted a diesel powered generator and started looking at the stand alones. those kubotas are super sweet but they are air cooled 2 pole units which means 3600 rpms to attain the 60 HZ. (EDIT: I see the lowboy is watercooled, nice machine but at 650 pounds you will need another machine to move it)
Started looking at water cooled, 4 pole units (1800 rpms), but the prices are crazy high for something that may not be used very often. Even considered the Lister types but they are not rated for much over 5kw and are definitely not portable.
The other option I was comparing to was to use a diesel powered tractor that I already owned and didn't really need for anything else and get a PTO genny.
That's the route I went, I got a 10kw pto genny from IMD, which I see now advertises here on TBN. So with the pto gen That solves the diesel power issue, along with portability, water cooled. The only issue I wish was covered is the high engine rpms required to make pto speed, I think mine is ~2600 rpm.
The reason all those smaller portable diesel gen sets are 3600 rpm is that to turn a 4 pole genny you really need at least a 3 cylinder to be able to lug it down that low and still produce the needed torque for the power needed, so you are still using probably the same fuel as when turning 3600 with a smaller engine like Soundguy says, but I still would prefer the slower turning engine.
So for the cost of a good stand alone diesel powered generator you could buy a pretty nice low hour tractor, don't need a loader or 4x4, and get a pto gen. You would find other tasks for the tractor and you wont feel guilty about the generator sitting around doing nothing.
Here's a link to a company that makes the water cooled 4 pole units.
Norpro | A Whole Lot More Than A Diesel Generator Manufacturer
JB.
   / Diesel Generator #15
soundguy
Soundguy, mower may or may not be apples-apples comparision, but I did a quick Google and found the below:
Decisions, Definitions and Generator Selection Criteria .
"3600 rpm engines tend to use more fuel than 1800 rpm engines per kilowatt hour produced by about 10 to 15% (not usually an issue for a backup generator) "
GiJoe, if you are planning on making any diesel of any size "portable" it will likely need to be trailer mounted.
RavensRoost
   / Diesel Generator #16
I think we may be mixing some terms here.. are you compairing 1800 rpm to 3600 rpm gen heads.. or the hizzbang engines.
remember.. a 3600rpm head on a pto genset is still going to be looking at the tractor's pto.. and likely pto rpm.. thus.. side by side.. I'd expect an 1800rpm head, and a 3600rpm head to ultimately use close enough to the same amount of fuel, based on electrical load.
soundguy
   / Diesel Generator #17
soundguy
I was talking about a generator set with its own diesel driver and opined one running at 1800 rpm (4-pole) would be more fuel efficient than one running at 3600 (2-pole). Did not mention it in my original post, but the assumption is that both would have same electrical load.
Bruce
   / Diesel Generator
RavensRoost
I've considered that, And the more I research the more I lean toward the Kubota Lowboy II generator. I haven't made up my mind yet, but at 650# I can load it in the back of my truck with my tractor. That will also ensure that the gen will come back home with me instead of leaving it somewhere on a trailer.
Joe
   / Diesel Generator #19
Bruce
with modern diesel engine technology.. my guess is the difference is going to be minutia..
soundguy
   / Diesel Generator #20
Climbed a mountain (1300') last month. This is what I found at the top.
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
UNUSED WOLVERINE PFF1-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
John Deere 30G Mini Excavator (A51691)
John Deere 30G...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
