Pics of X585 with R4s, how does it look?
   / Pics of X585 with R4s, how does it look? #1
dieselram
Gold Member
Meadville, PA
2007 John Deere 3120 TLBM
My buddy brought over his 2210 and I could not resist! I think they look sweet, but the ride is a little harsher. Well worth the trade off I think- it looks like a tractor now. Please help me find a set! I will lose sleep until I do.
   / Pics of X585 with R4s, how does it look? #2
That looks like a tractor should!!
Well, I don't know about a tractor but a garden tractor on steroids maybe.
   / Pics of X585 with R4s, how does it look? #4
Hi dieselram ,
Those really look good on your Tractor and I could deal with the harsh ride ,
but my question would be , how will they perform in different work
environment scenario's , [ mud , snow , pulling , pushing , ect. ] , to bad you
can't borrow them for a day or a couple of months and give us a review ...
What ply are they , 4 or 6 ???
Thanks for the pictures !!! :)
Later,x595
   / Pics of X585 with R4s, how does it look? #5
I like the look. My old 595 had the HDAP tires. I thought they were great for traction, especially in mud. They also ran very low pressure so they would not damage grass. The only problem I had was when I bought a little 45 front loader. With even a 300# bucketload of something the sidewalls flexed and wobbled, even appearing as though they would go flat. I would see an advantage in using the R4 tires on an X series if one were lifting heavy rear implements, such as a box blade, or using the front loader that is available because they have a better load range and stiffer sidewall (which is why they ride rougher). Otherwise the HDAP tires get better traction in most cases and will not likely damage a finished lawn. I suppose they still remain the best choice for an X series style tractor for these reasons.
John M
   / Pics of X585 with R4s, how does it look? #6
I like the look. My old 595 had the HDAP tires. I thought they were great for traction, especially in mud. They also ran very low pressure so they would not damage grass. The only problem I had was when I bought a little 45 front loader. With even a 300# bucketload of something the sidewalls flexed and wobbled, even appearing as though they would go flat. I would see an advantage in using the R4 tires on an X series if one were lifting heavy rear implements, such as a box blade, or using the front loader that is available because they have a better load range and stiffer sidewall (which is why they ride rougher). Otherwise the HDAP tires get better traction in most cases and will not likely damage a finished lawn. I suppose they still remain the best choice for an X series style tractor for these reasons.John M
Hi John ,
Why did you get rid of your X595 ??? Just curious ...
I don't have the 45 front loader , but I see what your saying about the
weight issue ...
Later,x595
I have a 4300 so I don't really need to do anything other than push a little snow and mow alot of grass. Main reason-THEY LOOK COOL AS ****!
   / Pics of X585 with R4s, how does it look? #8
Thanks for asking. I got rid of my 595 mainly due to a change in my residence. I took a new position in the mountains of Western NC. Where I lived prior, I had about four acres of grass to mow, plus my parents' place on a regular basis. I also moved a little dirt with the front blade and pulled a cart around hauling various things. When I moved, my wife and I bought a nearly seven acres plot about two hours from my original residence. I hired out much of my parents' mowing. We have property, but it is almost entirely wooded. Thus, my needs changed from more of a large volume mowing need to one of box blading a long steep gravel drive, hauling large amounts of stone and mulch and doing things that one really needs a tractor for. Although sprightly, the 45 loader simply was not up to the tasks I needed it to do and the tractor hydraulics were very limited in what they could do, so I traded into a compact tractor. I loved my 595 and had I not moved, I would certainly still have it.
John M
   / Pics of X585 with R4s, how does it look? #9
I like'em!
Yeah they are pretty cool, bet you have never seen an X with R4s have you?
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
2016 VOLVO EC380EL EXCAVATOR (A51246)
2016 VOLVO EC380EL...
2014 Chevrolet Silverado 4x4 Pickup Truck, VIN # 1GC1KXEG9EF156183 (A51572)
2014 Chevrolet...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
