Farmall cub hydraulic leak
   / Farmall cub hydraulic leak #1
North Georgia
Lula, Ga
Kubota9000 Farmall Cub
Have a 53 Farmall Cub and the lift reservoir has a leak. Does this take regular hydraulic fluid? Thanks
   / Farmall cub hydraulic leak #2
Reg hyd oil is all I've put in mine for years and never had any problems.
   / Farmall cub hydraulic leak #3
Yes Reg Hyd Oil is called for. Don't put hy-tran in it.
Is the leak in the reservoir or the cylinder?... well my Cub leaks both places, but not enough yet to break her up.
Leak appears to be in bottom of reservoir. It is not really bad yet. Put some hydraulic oif in reservoir to bring up to full mark. This seems to have solved my problem. I did notice that Farmall Cub. com has a complete rebuild kit for the system for about $40. Will consider that if needed..
Thanks for your input.
Farmall A Tractor w/Belly Mower (AS IS) (A50774)
Farmall A Tractor...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2012 Ram 4500 Chassis Vesralift Bucket Truck (A50323)
2012 Ram 4500...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
