NH 256 adjustment ?
   / NH 256 adjustment ? #1
disco
Minnesota, Goodhue County
JD 4310 & JD 4020
I have a NH 256 rake. I have never owned one. It has a slot for adjusting it up and down in the front. We are raising alfalfa. If anyone knows where it should be set at please let me know.
Thanks Paul
   / NH 256 adjustment ? #2
Thanks Paul
The manual says set it back (up) for lighter, fluffy windrows and foward (down) for a tighter, more roped windrow. I run mine in the upward mode but I bale just grass hay.
Thanks for the reply! It is set towards the bottom. I cut about 1 acre to test the NH 499 and the 256. It did kind of rope it up which gave me a few wet spots. Overall worked good. I will reset before cutting the rest.
Thanks much,
Paul
   / NH 256 adjustment ? #4
Just curious. What size tractor do you use with the 499 ?
We use a JD 4020. Worked great. Could'nt tell it was back there. Not sure if I have the rolls set right. Alot of the stems were breaking, not cracking. The man I got it from used it to cut 110 acres of CRP a year. It's in really good shape. He never worried about conditioning.
Thanks Paul
   / NH 256 adjustment ? #6
Check to see if the rolls are "in register", meaning that the chevrons line up with out interference. There is an adjustment for this that allows you to rotate one of the rolls relative to the other. The hay should go into the chevron pattern but not be snipped at the edges. Look for rubbing marks on the rolls as a tip off that this is happening.
Thanks for the reply,
I think I need to back off the roll presure. There is about 3/8" gap between rolls. They seem to be in sync. Nothing hitting anywhere.
Thanks Paul
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
2011 Ford Fusion SE Sedan (A51694)
2011 Ford Fusion...
2024 Rhino 4155 Batwing Mower (A53473)
2024 Rhino 4155...
1999 MORBARK 3800 WOOD HOG GRINDER (A53426)
1999 MORBARK 3800...
