Leaking faucet
   / Leaking faucet #1
BarryinMN
Minnesota
JD, Allis-Chalmers, Zetor
Anyone know the secret to fix - it's leaking from under the top cap?
   / Leaking faucet #3
Well, they may all be slightly different, but I had the same problem with one of mine, went to Home Depot, Lowe's, Locke Plumbing Supply, ABC Plumbing Supply, and two other hardware stores. My faucets have no brand name, model number, etc. that I could find. I finally found "similar" but not the same parts at a hardware store. But a year or so later, I had the problem again. And that time, I happened to notice the damage to a rubber o-ring. I discovered that all I ever actually needed was a new o-ring for a few cents from Ace Hardware.:eek::eek: Some of those top caps are metal and are screwed on, some are plastic, and just snap on, but they have the same problems and the same fix.
Now of course that's the experience I've had; your problem may be different.
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
1997 Tiffin Allegro (A50120)
1997 Tiffin...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
