Replaced fuel pump now won't run J/Dere
   / Replaced fuel pump now won't run J/Dere #1
rayikeo2
I have a LX279 John Deere mower. The fuel pump started leaking out of a vent hole. It was running good except for the leak which was dripping on the muffler cover. I replaced the fuel pump with a new pump and It started right up ran for about 30 seconds and acted like it ran out of gas but the tank was full. I don't have a Tech Manual to referance so I need some advice from some of you with more experiance. Can you give me some ideas to check or point me to some information on the net or anywhere so I can get this mower running again. My grass is getting high. Thanks
Since none of you could or would help me after a lot os searching the internet working and cussing I fixed it my self without your help. Next time I will find a new forum to try for help.......:rolleyes:
   / Replaced fuel pump now won't run J/Dere #3
Gee, talk about sour grapes!
Maybe, just maybe, NO ONE here has ever had the same problem you did!
Adios-good riddens:D
   / Replaced fuel pump now won't run J/Dere #4
WOW !!I guess you really had a bad day.I find you will be hard pressed to find a forum with this much knowledge.Good luck to you.coobie
   / Replaced fuel pump now won't run J/Dere #6
Let's see, ran in, now doesn't run. Must be something you did. Start by checking fuel pressure and volume. No fuel coming out of pump? Check for air leaks on feed side. Loose connections on supply side could be drawing air instead of fuel. You should be able to feel a suction on the supply side of the pump. Also, make sure you have fuel in the tank! (don't ask me how I learned this)
I could have used that information earlier.:cool:
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2006 HAMM 3205 SMOOTH DRUM ROLLER (A51246)
2006 HAMM 3205...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
