skid steers: Bobcat S220, Cat 262B?
   / skid steers: Bobcat S220, Cat 262B? #1
Ken45101
Elite Member
southern Ohio
Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
I'm considering buying a used skid steer. General around the farm work, clearing trails, etc.
One problem I have is that I need hand controls. I have a back problem and no control of my left foot, so normal foot controls don't work well for me.
I've looked at a Bobcat S220 (1200 hours). There is also a Cat 262B on Craigslist (2000 hours). Any thoughts or comparisons of these two?
Other machines that I ought to consider?
Thanks,
Ken
   / skid steers: Bobcat S220, Cat 262B? #2
You might like the control better in the s220 depending on the year and software updates. the b series CAT's pilots are very sensitive.
   / skid steers: Bobcat S220, Cat 262B? #3
I would probably go with the Bobcat out of those two.
I run a 236b with pilot control a couple a winters ago and it was the biggest peice of excrement I have every run as far as skidloaders go.
Both are 2005.
Thanks for the insight. Is the sensitivity something one can get used to?
I also heard about a 2002 JD260 with hand controls that will be available although his price seems on the high side.
   / skid steers: Bobcat S220, Cat 262B? #5
Both are 2005.
I have a JD skidloader and think you can't beat them
But I dont like there hand control pattern (it is like a Case)
No, not in the Cat anyway
   / skid steers: Bobcat S220, Cat 262B? #6
Before I got the Kubota I have I rented several different models - I would suggest that you call around - then visit rental shops and rent a skidsteer that would meet your needs - use it for a day or so and then make a choice...Renting allows you to make a $250.00 test run before you spend the cash.
   / skid steers: Bobcat S220, Cat 262B? #7
Yeah, rent one. Wow, I usually write a lot more than this.
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
