Which finish mower do you guys think is a better buy?
   / Which finish mower do you guys think is a better buy? #1
TractorRob
Middle Tenneessee
Mitsubishi MT3201D
   / Which finish mower do you guys think is a better buy? #2
hands down no exception the bush hog, been around a long, great rep., built like a tank, with proper care will out last the tractor, and parts are avaliable and will be 20 years down the road and at just about any tractor/implement dealer!
   / Which finish mower do you guys think is a better buy? #3
I currently have a Bush Hog model 285 rotary cutter and had 3 Bush Hog Squealer rotary cutters in the past, but have never used either one of those brands of finish mowers. I know which one I'd buy though if I were you- the Bush Hog. I wouldn't even second guess it.
Travis R
   / Which finish mower do you guys think is a better buy? #4
Maschio Jolly? That's a mower? Sounds like a fu-fu drink. :)
I know I haven't been around much but that's the first time I've ever heard of that mower.
   / Which finish mower do you guys think is a better buy? #5
You can get a brand new 6ft Sitrex rear finish mower (rear discharge) for about $1200.00 with new driveshaft included.
Sitrex (made in Italy)
I have owned one and it mowed 7 acres every 10 days for 3 years and only had to adjust the belt once. It is a great mower for the money.
If you dead set on the two mowers pictures I would go with Maschio.
You can get a brand new 6ft Sitrex rear finish mower (rear discharge) for about $1200.00 with new driveshaft included...
Where? By they way, I see that you are in Tennessee. I am in Middle Tennessee(I thought that I had put that in my Profile, but apparently hadn't. It's in there now).
   / Which finish mower do you guys think is a better buy? #7
   / Which finish mower do you guys think is a better buy? #8
I have a maschio tiller and i can tell you that is built like a tank..... I would expect the same from the mower....
   / Which finish mower do you guys think is a better buy? #9
Never used an MJ, but I have used a Bush Hog RFM. It cut great, strongly built, yet was't overly heavy. You can't look at specs on a RFM. You have to eyeball them. Things like wheels, shafts, belt adjustment can give you a real pain if they're not rugged and well designed.
Thank's for your suggestions. Though both mowers look to be in good shape from the pictures, I would have to drive a pretty good distance to see either one(and they are in opposite directions), so I had not seen either mower in person. Yesterday, I stopped by a tractor dealer not far from me and he had a used Woods RD7200 that looked almost brand new for $1100, so I bought it. I hope I got a good deal, what do you guys think?
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2012 International 4300 Reefer Truck (A52748)
2012 International...
1993 Ford F700 Stakebody Truck (A51692)
1993 Ford F700...
Shark SM3540R.3 4000 PSI Pressure Waher (A50325)
Shark SM3540R.3...
